Question about SAMTRON 55V 15" CRT Monitor
Problem with the vga cable
Hello, my cpu was stoled and the bad guy cut the vga cable. i can put a new db conector but i havent how the wires get into the pins. could anybody the colour sequence in the db15 conector for this monitor . thanks and i`msorry about my english i want colour code of cable of monitor to cpu with pin nos.
  • Anonymous Mar 27, 2014
    VGA cable was cut
  • 151 Answers
Put the connector infront of you and take biger size to top and smaller to down then count the pins like this-1=red,2= green,3 =blue(count the pins right hand side to left hand side),4=ground,5= blank,in lower row 6=red ground,7= green ground,8=blue ground,9,10,11=blank,12,15= in command section,13=horizantal synk,14= vertical synk.Hope this solution works otherwise i am always for help you.
Posted on Apr 03, 2008
SOURCE:
I'd like to know how to assembly a 10 wire isolated cable with a VGA connector
Pinout of the VGA conector.
http://www.pc-control.co.uk/vga_connector.htm
Apr 26, 2010 | InFocus VGA Cable - 15 pin male-male, 4...
Vga conector
there's no problem with the color (black,white,blue) it's doesn't matter.
Dec 17, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My VGA plug is missing on my monitor
If the cable does not disconnect from the monitor, then go ahead and buy a new connector http://www.startech.com/item/C15HPSM-High-Density-DB15-Male-VGA-Solder-Connector.aspx
I recomend this over buying a generic VGA cable and splicing wires, for better connectivity and less 'noise'.
Aug 06, 2009 | Neovo F-417 17" LCD Monitor
ACER AL1715ebm LCD MONITOR BAD VGA CABLE
you are in a bad spot, the plug is sealed when molded. maybe ebay has a defective monitor and you could take the cable off it.
Monitors will usually snap apart with a butter knife.
Jan 27, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
Speedomoter cable plug has been unpluged and the wires cut
hi there, yea for a quick fix that is what i would do. just make sure they wont touch anything metal that would cause it to short out on you
Jun 02, 2008 | 1992 Nissan King Cab
Phillips VGA Cable colour chart
you can use any vga monitor with the same color output and resolution setting just goto craigs list in your town and look for someone throwing one out detach old cable and reapply to your screen by either soder or splicing the wires independently together this is tricky
http://www.lammertbies.nl/comm/cable/VGA-monitor.html
Pin Name Function 1 RED Red video 2 GREEN Green video 3 BLUE Blue video 4 n/c not connected 5 GND Signal ground 6 RED_RTN Red ground 7 GREEN_RTN Green ground 8 BLUE_RTN Blue ground 9 VDC 5 VDC supply (fused) 10 GND Signal ground 11 n/c not connected 12 SDA DDC / I2C data 13 HSYNC Horizontal sync 14 VSYNC Vertical sync 15 SLC DDC / I2C clock
Jun 02, 2008 | Philips 107E66 17" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
206 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Ekse
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
