Question about Muratec M1250 Fax
Error message - "check Rec. Paper"
I actually have a Muratec M1220, but this page kept telling me it was not a valid product -- so M1250 sounds close enough. I just received this thermal fax machine, without a manual. I get message "Check Rec. Paper" when I plug it in. What does this mean?
    Genius:
  • 1,218 Answers
Check rec. paper means that the paper may not be routed properly thro' the cutter mechanism and out thro' the machine....if it is; then the sensors that detect the paper may be dirty or faulty.
Posted on Aug 19, 2010
  • abp20 Aug 19, 2010
    Check rec. paper means the paper is not installed correctly or the eyes that detect the paper are dirty or faulty.
Muratec F-320 Super G3 we are getting a fax ready Please call Service message
Please Call Service means the machine "thinks" it has detected a fault.
To check do the following..
Press PROGRAM,*, 6
Then press PROGRAM to select Service Call mode, then press ENTER....the error message will be displayed in the display.
Most common error given machine age was "Heater Error".
If this is the case you will need a Serviceman to do repairs to the Fuser Unit.
Oct 25, 2010 | Muratec F320 Plain Paper LED Fax
Check Rec. Paper
Roll of paper is not threaded thro the cutter mechanism properly...or the sensor may be dirty.
Aug 17, 2010 | Muratec M2500 Fax
NOT ABLE TO SEND FAX WITH ADSL LINE
Can you pick up the handset and dial a number and speak to the other person using the handset..?? You might just require a filter which your telephone company should be able to provide.
Aug 02, 2010 | Muratec M1250 Fax
Fax thru Internet help
Magic Jack is lying to you. ALL fax machines are Analog devices, Magic Jack is Digital
Jun 21, 2010 | Muratec M1250 Fax
Muratec f320 states: fax ready please call service it continues to send faxes but is not receiving
F-320 "Please call Service".....Press PROGRAM,*,6.....Press PROGRAM to select "Service Call"....error message will now be displayed.
Most common is #02 (Heater Error) which means you have a defective fuser.
Press PROGRAM to show any other error messages.
Press "STOP" TO EXIT.
May 14, 2010 | Muratec F320 Plain Paper LED Fax
CALL FOR SERVICE MESSAGE ON A MURATEC MFX1200
Yes the Call Service Message on Muratec is directly tied to Imaging Unit replacment. Especially if you are not getting any codes in the display.
Oct 20, 2009 | Muratec F320 Plain Paper LED Fax
Paper jam message but there's no paper
There should be an exit sensor, as part of the fuser unit, I suspect it either has not been connected or is physacally jammed out of position. Check these areas, and also for pinched wires.
Hope this helps.
Ed
May 07, 2009 | Muratec MFX-1500E Plain Paper Laser Fax
Muratec m 1250
Probably just needs cleaning. Try using rubbing alcohol to clean the head.
Feb 11, 2008 | Muratec M1250 Fax
Muratec mfx-2000 error problems
please check the switch of mentioned cover may be it is abnormal or open and close the front cover or check may be there is one reset switch in your machine
Sep 26, 2007 | Muratec Copier
Fax Numbers-Memory?
Unfortunately that is a function of the sending unit. If they did not program their number in, then you won't have a record. If this is a persistent problem, you may want to sign up for Caller ID. Even if they put the paper in upside down, your fax will still print a head on top of the page with the information they have programmed. If they program a wrong fax number, then all you will have is a wrong number. Wish I have better new for you. Ed
Jun 13, 2007 | Muratec M1250 Fax
Muratec M1250 Fax Logo
167 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
