Question about Canon L220 Plain Paper Laser Fax
Keep saying change cartridge
Even after changing the toner cartridge fax keep saying change cartrige any help
Yes i found one spring was out of its place it is near the paper feed assembly.
After placing the spring in its hinges the problem was solved.
Posted on Apr 02, 2008
Sf 5100 - new ink cartridge says toner empty?
take the new cartrige out. you will see there is a fuse on it. take it out and put new fuse any amp. put the cartridge back and close the door for 2 sec. take the cartrige out and remove the fuse. put it back in. it should work.
if not push setup
#1
9
set up again
you will find under the setup a toner egnore put it on.
and swich unit off and on.
Aug 15, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Ink cartrige problem i replaced both cartriges keeps saying right cartrige is incorrect wont let me print
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
I get a white line through but it is not telling me to change toner?
This can occur if you receive a lot of faxes that may have a vertical block or a lot of text or pictures etc. in the same location on the page. The toner can be used in that particular area of the page and a white line results.
Remove the toner cartridge from the fax, keep it horizontal. Shake it side to side whilst keeping the cartridge horizontal. This redistributes the toner inside the cartridge. Replace the toner cartridge in the fax.
Hope this helps.
Feb 09, 2010 | Brother IntelliFax-2820 Laser Fax
Right side of Print Out is faded. Cleaned, and Cleaned. Doesn't say to change drum/ink. What else can we try?
You can try shaking the toner cartridge to even out the toner but most likely either need a new toner cartridge or the drum is not sitting evenly as it should.
Sep 11, 2009 | Xerox WorkCentre Pro 555 Plain Paper Laser...
If we already changed ink cartridge, why would the toner still be low?
have you bought non compatible cartriges i have that problem after replacing epson inks i have the orange light on all the time now
Jul 13, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Changed the Toner in Fax Machine and Still reads "Low Toner"
First, the obvious
  • Did you gently rock the toner cartridge from side to side to evenly distribute the toner?
  • Did the cartridge "click" into place?(did lock lever pop up when it was inserted)
  • Did you replace the protective cover securely?
Another thing to check is cleaning the Corona wire inside by sliding the Blue tab back and forth several times. Important to return the Blue tab back to the "Home" position afterward.
If you've done ALL of these steps correctly, and the low toner message is still there, a service call is in order. Best of luck with your machine!
May 06, 2009 | Brother IntelliFax-2920 Fax
Cleaning the Xerox Workcentre Pro 575
More than likely, you have a bad toner cartridge.
Nov 12, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Brother 2820
The toner cartridge is in the drum unit. push the blue lever and the toner pops out, make sure you have a toner cartridge in the drum unit. Lawrence
Apr 23, 2008 | Brother IntelliFax-2820 Laser Fax
Gear grinding noise
Sounds like it could be the toner cart is not mating properly. Sometimes this could be simply that the spring and flap arrangement on the plastic case of the cartridge has become misaligned. It is not necessary to have the flap(cover) present once the cartridge is installed in the machine. Just remove it in it's entirety if you can't re-align it.
Jan 25, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Canon L220 Plain Paper Laser Fax Logo
134 people viewed this question
old marine
old marine
