Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag gemini f1-9 error
Today I boiled water on the back right burner of my stove.  I left it boiling for a few minutes and returned to the kitchen when I heard the machine beeping.  It reported a F1-9 error, with the burners still working.  I unplugged the machine for about an hour.  When I plugged it back in, the panel appeared to be going through its regular start up, but then the screen went blank.  I unplugged it again, and then later plugged it back in to use the burners.  At that time the panel read nothing.  Later, the beeping/error message returned and the clock came back on.  I cannot get the ovens to work.  One the oven control side of the panel, only the cancel buttons appear to be working, and on the numeric keypad, some of the keys beep when pressed.
  • 1 more comment
  • Sheils10 Apr 02, 2008
    Cancel button did not work.
  • Anonymous Nov 01, 2008
    roasting pumpkins in the oven (left pumpkins in the oven), turned oven off and went out for 1 hour. When I returned I got the message to call a repair person and F1-8. Continual beeping and the control panel doesn't seem to be working. Tried unplugging the range but still getting F1-8 message when I plug it back in.
  • Anonymous Feb 12, 2009
    FI-9 CODE
  • 185 Answers
Plug it back in and press the cancel button
Posted on Mar 31, 2008
Only one burner doesn't work on my maytag gemini stove
MET8776BS Maytag Gemini Smoothtop Double Oven Range
reviews.us-appliance.com/.../MET8776BS-Maytag-Gemini-Smoothtop-D...
Rating: 4.5 - ‎94 reviews MET8776BS Maytag Gemini Smoothtop Double Oven Range - Stainless Steel - Reviews ... Really like the features, however one burner doesn't work, after a month.... 2 ovens sure beats the storage bin underneath! the only negative I can think of is ...I bought my double oven a few months ago and am very happy with it.
Oct 16, 2015 | Maytag Kitchen Ranges
Electric range for maytag gemini stove doesn't coem on. Clock and controls appear to function. This is after I turned the house's breaker off then on again. The "On indicator" light does not come on when I...
Turn it off at the circuit breaker and leave it off for a few minutes,sometimes the microprocessor will reset itself. When you turn it back on make sure the safety switch is working ok they usually have a test button on them.
May 01, 2014 | Maytag MER6772 Gemini Electric Kitchen...
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
My burner gets excessively hot very quickly is this normal?
That right front burner is an extremely hot burner by design. It is sold as a quick power burner. The rating on it is 12,000 btu's meaning it could easily boil a pot of soup in that time.
Here is a quote from the owners manual for your range
"There is a 12,000 BTU*
burner located in the right front position. These burners offer
higher speed cooking that can be used to quickly bring water
to a boil and for large-quantity cooking."
Use the back for slower smaller cooking and front for larger and quick heating.
I hope that helps.
May 09, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Woke in the middle of the night hearing the ignitor on the gas range going nonstop. We ended up unplugging the stove to get it to stop. What is this problem about?
Usually a bad ignitor switch, but can also be wiring or a spark module. Leave it unplugged for a few days to dry it out. Moisture gets into the ignitor switches if you have a boil over, or if you get a little over exuberant about cleaning around and under the burner switches. Quite often we get this problem when someone sprayed cleaners on the stove surfaces to clean it and the moisture got into the switches under the knobs. If this still clicks after it has dried out, you will have to have a serviceman out to diagnose which of those three problems it is. Good Luck, Appliance Specialists
Jan 29, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Has anyone else had a serious problem with the electrical wiring in their Maytag Gemini Gas Range? Without using the stove, the ignitors started firing and then stopped when I turned all the burners on....
Same problem here - and I have read about others with this problem. Usually blamed on moisture getting into the control unit ( which is under the backmost burner knob). I did not have a spill on the cooktop, nor was I "over zealous" cleaning. Looks like a bad design. Waiting to hear from the technician how much THIS is going to cost me...
Jan 02, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Hello My gemini top burners cycle on and off,
The burners are designed to cycle on and off, it is technology that helps to keep from burning food. If you are using the correct pan to burner size ratio and high setting on your burner, the water should boil in the normal time. Don't watch the pot (just kidding)
Nov 30, 2009 | Maytag Gemini 30" Self-Cleaning...
Clicking sound on my gas stove
You just need to turn the knob a bit more, thats the igniter you are hearing.
Mar 17, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
there switches behind each knob, 1 of them is broken,or wet, when you remove the knobs then remove the knob panel you can test them and find the bad one,they are no more then $15.00 each. to test you can plug the stove and disconect the switches one at a time until you find the bad one replace and you are back in bussines.
Dec 11, 2008 | Maytag MGR5770 Gas Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
488 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
