Question about Sony 1GB Memory Stick PRO Duo Memory Card
1GB Memory Stick PRO Duo Memory Card: My sister's boyfriend put my stick into his comput...
My sister's boyfriend put my stick into his computer to upload the picture and the computer changed the format of my memory stick and now when I put the stick back into my camera it says formating error. I dont want to repair the format until I get the picture's off but the memory stick's not working with my computer now!
    Genius:
  • 1,234 Answers
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Posted on Aug 27, 2010
My computer (HP DV 5200TX) is not reading the memory stick duo. What steps can I try?
I didn't know that HP built computers with card slots that support MS pro duo. Try getting a mini-usb cable, leaving the card in your psp, and plug the PSP into your computer. Make sure you set the PSP to connect using the USB first, though.
Feb 11, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
My pc does not read the memory stick PRO duo sony...
my memory pro duo in camera show picture , when it conect with computer ,picture no t show.how can i do?
Dec 30, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Where and how do you put the memory stick pro duo memory card in your computer/laptop?
First check whether your computer have aport for that. Foe ensuring it call the customer care of sony which iwill be a toll free number ask them with mentioning your specific model number.
Or you can just buy one cheap memory card reader which supports sony Memory Stick PRO Duo Memory Card. Its very cheap, i am sure you can afford it. Its good for you as one single card reader will support lots of types of memory cards and sticks.
Oct 06, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 17, 2010 | SanDisk 1GB Memory Stick PRO Duo Memory...
    Memory stick pro duo
    LLFTOOL is a utility for low-level disk drive formatting,
    also supports formatting of FLASH cards using a card-reader.
    1. Download this tool:
    http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
    2. Format stick pro duo
    (WARNING: After running this low level format tool,
    the whole USB flash disk surface will be fully erased.
    Therefore, data restoration will be impossible after using this utility!)
    Jan 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
    My Memory Stick does not register to my Macbook Pro. I have put it in the the SD slot countless times every way.
    memory stick pro duo slot is different from SD slot. get a inexpensive card reader which supports memory pro duo cards.
    Aug 07, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
    Formate memory stick
    try formating the card using a digital device such as a camera or a playstation portable (PSP)
    May 17, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
    Need pictures off memory card
    More than likely this is not a memory stick problem, but a computer problem. Have you used this port before for other uses? sometime a port will get sloppy( for lack of a better word) and you may have to tilt or hold the card with your hand, so that the computer will pick it up. Try that.
    Hooe it helps.
    Mar 05, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
    Sony memory stick pro duo is too small to fit in my computer media stick compartment. it won't read
    its to small b/c when u bought the media stick it should have came with an adapter that you put the stick into and it makes it bigger inorder to fit into the computer.
    Sep 17, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
    Sony 1GB Memory Stick PRO Duo Memory Card Logo
    Top Sony Electronics - Others Experts
    Sandy Moore
    Sandy Moore
    Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
