Question about Asko D1776 Stainless Steel Built-in Dishwasher
ASKO 1595 daer greendude, indeed your troubleshooting was right!!!! i pulled out the dishwasher and the base was full of water. once i got water out, the fault sign went away and it's ready to run its normal cycle. now i need to figure out where the leak comes from: either the fitting or the valve itself. just in case i have to replace the valve: any good source to get it from? i live in california. once again, thank you much!!! i'll keep you posted on the developments
    Sergeant:
  • 351 Answers
I live in australia our part no is 8052120
Posted on Apr 02, 2008
Remove the kick plate or panel from dishwasher 1595
I have a different Asko model so this may not apply. The screws are Torx and you need the proper fitting. Everything is symmetric with the same screws and locations on the left and right. Mine has two screws for a front kick panel, two screws for the front trim piece that matches the door, and then four screws, to on the underside of the cabinet and two on the front to remove the final piece. There are also two adjusters that slide out after pressing a tab on the outside of the slider.
Sep 27, 2014 | Asko Dishwashers
Hi i have a asko d3111 the pump is running the washing icon is flashing.i have cleaned all of the filters how do i reset it
i have an asko3132 washer starts but no water coming into washer then stops and displays error F7 have cleaned filter do i reset if so how
Jun 14, 2011 | Asko 1595 Dishwasher
D1876 Asko dishwasher doesn't fill. It runs fine if I manually fill the unit with a couple of pitchers of water. Likely culprits seem to be a faulty water level sensor or water fill valve. Any...
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1876 and 2) not filling with water...It sounds like a faulty fill valve/water valve unfortunately.
First though, you can perform a diagnostic/fault trace program by following the steps below. You should hear the valve starting once the unit has started filling with water.
You'll need to be familiar with the control layout for the test to begin. This is how the buttons/display is identified in the diagnostic...
Now you can enter the fault trace by way of the following sequence....
Obviously based on the instructions if you push S3 the valve should open and allow water into the tub, this image below indicates the normal water level to look for when filling in the normal cycle NOT FAULT TRACING...Fault trace will fill until you stop it.
This unfortunately is common with Asko built dishwasher`s, but it can be fairly easily repaired with a little direction/know-how.
**First turn off the water and the power to the dishwasher...safety first**
You should only need to remove the toe panel/kick plate at the bottom and of course turn your water and power off, undo the water line at the valve,
i.e.
...remove the two torx screws ( large arrow ) and then the delivery hose at the back of the valve ( small arrow ) and install the new one.
The new valve is part # 8801351 and available at on-line parts depot "repairclinic.com" for about $170USD last time I looked.
Let me know what you find and I'll try and help you move forward from there...you may opt to call in a pro but that's up to you.
I'll watch for your reply.
Regards,
Macmarkus :)
Jan 30, 2011 | Asko D1876 Dishwasher
It doesn't sound like the dishwasher jet arms are spraying water and the dishsoap was still on door at end of cycle.
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1716 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately.
First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? And be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump obviously it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues.
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet...you may opt to call in a pro.
Regards,
Macmarkus :)
Jan 29, 2011 | Asko D1716 Built-in Dishwasher
I just installed an Asko 1595 I need an operator manual
Welcome to FixYa.
I can send said guide if you provide an email address, you can likely score one at Asko web-site.
Let me know.
Regards,
Macmarkus :)
Dec 15, 2010 | Asko 1595 Dishwasher
Asko dishwasher starts and immediatly stops
Hi mike, thanks for the clarification. Having this info, I am not sure this model is as the post indicates - "1595". Is it possibly a 1473 or 1474 model with a power button by the door handle ? If so, that is the most common problem with that style Asko. The contacts inside the button make momentary contact & then stop which requires replacing tge switch. Let me know if it is indeed one of these models or confirm what model number it is ok ? Thanks, Macmarkus
Apr 22, 2010 | Asko 1595 Dishwasher
My asko dishwasher model 1595 flashers a f-2 code. I checked for a cloged drain. used my shop vac to empty the water in the drip pan then restarted the dishwasher.The pump came on and it continued to fill...
F2 High water level · Plugged/Bad water pump
· Defective water inlet valve
also check that the float switch is not stuck in the up position...
Hope it helps if NOT let me know more about your problem... and I will help
Aug 25, 2009 | Asko 1595 Dishwasher
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
Asko dishwasher problem
Hello, What you are describing is called an overfill. Sometimes programming, soap usage or installation can cause this. ASKO Customer Service will be able to give you troubleshooting tips and will most likely be able to fix this issue right over the phone as this is typically an easy fix. You can contact the ASKO Customer Care Group at 1-800-898-1879. They are open 24 hours a day, 7 days a week for your convenience. Sincerely, AM Appliance Group
May 28, 2007 | Asko 1595 Dishwasher
Asko D1776 Stainless Steel Built-in Dishwasher Logo
169 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
