Question about Nokia N95 Cellular Phone
Problem with my N95
Hi, i have porblem with my set
when i power on my phone it continously searching for signals and destop light getting on and off and no function is working.
    President:
  • 1,017 Answers
Try this reset code *#7370# you're likely to loose your data. If it works check if an update of your phone software (firmware) is available, on Nokia of your area. This is for Europe:
http://europe.nokia.com/A4144905
Posted on Apr 02, 2008
SOURCE:
I forget mt my Nokia 6300 security code. please help me
if you not lock the systum which asking did want lock ever sim change or no if you did not please change your sim card it well open other wise wait i have also this porblem in Nokia N95 GB
Apr 08, 2010 | Nokia 6300 Cellular Phone
Nokia 6120c only has gsm signal near a tower. How do we make it work better. Is it not set for canadian best reception
Perform a manual network search on your phone and reconnect to your network. That may provide a signal boost.
Nov 09, 2009 | Nokia N95 Cellular Phone
Hi there, i have a Nokia N95 8gb and the problem is when i put my sim card in and start it up, the signal bar gives me 2 bars max or one bar sometimes or sometimes no serice when im outside. i tried 2 sims...
Select Menu- go to settings -select network-change operator selection to manual your mobile will scan for the network and select the network and check the signal strength..If signal strength is still low contact your operator (customer service).
Oct 20, 2009 | Nokia N95 Cellular Phone
Cant get my nokia n95 to search for blue tooth headset
first swithch on your bluetooth of your mobile, then from its setting of bluetooth chenge the status of availblilty into "show to all" then search ur n95 bluetooth headset,
i hope your probliem will be solved
thnx n regards
ahsan ali
Aug 29, 2009 | Nokia N95 Cellular Phone
My Nokia N95 gps doesn't work after I change my casing. I tried using the gps data but it only get me 1 sattelite signal,though it were seldom.
This problem usually occurs, when your old data resides and , when it is not able to replaced...
This can be rectified by RESETTING YOUR PHONE TO FACTORY SETTING once..
Navigate to SETTINGS_>SECURITY->RESTORE TO FACTORY SETTING
Now try connecting GPS, it should work,
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 27, 2009 | Nokia N95 Cellular Phone
Cant delete header N95 8GB
Sounds like data coruption, the easiest and most reliable way fix this is to perfom a factory reset. A factory reset will only wipe the phone contents and leave the Mass memory data in tact, backup all important to to you Mass Memory and perfome a factory reset.
found in menu -> tools -> settings -> general -> Factory Settings. defualt code is 12345.
this will fix your problem, and about 99% of other software porblems with these phones.
Jan 05, 2009 | Nokia N95 Cellular Phone
How want to activated gprs/mms on my n95 china mobile
For china mobiles manuals, software and drivers check chinamanuals.com (search for your model or just ask them)
They have a N95 user manual incl. network settings for major providers for download.
Nov 10, 2008 | Nokia N95 Cellular Phone
Continiously restart
if any problem arises in china mobiles it will be continued better buy branded one
Oct 15, 2008 | Nokia N95 Cellular Phone
N95 problem
I have the exact same issue, my N95 keeps on restarting on it's own. I can only make or receive calls. Any idea what the issue is?
Jul 10, 2008 | Nokia N95 Cellular Phone
Nokia n95 web
You have to get this function switched on on some networks contact you service provider and ask if web browsing is enabled.
Dec 13, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
