Naiko tv/dvd model No. N1003. Sound is ok but no picture. Picture flashes on momentarily when changing mode between dvd/tv/aux/monitor.
Shuttle83
  • 1139 Answers
SOURCE: No color
Hello Ivolvo, This problem denotes a problem with your color section of your TV. First I need to know if you have a background in electronics because if you do not it will be very difficult for you to understand what I am talking about. First you will need a schematic diagram of your TV. Then you wil need a multimeter to measure voltage and resistance. Then you will need an oscilloscope, finally a sisgnal generator (use color bars, or gated rainbow). These pieces of equipment will allow you to troubleshoot your problem. If you do not have a background in electronics, please take you set to an electronics shop for repair.
Posted on Oct 08, 2007
SOURCE: repairing lcd tv.
thanks very much about your technical support.but i solve allready the problem of LG LCD TV MODEL LT-15A10 TROUBLE; no picture with sound, i replace the socketed ic SDA555XFL62 PINS. THANKS... LODIVAR.
Posted on Feb 18, 2008
  • 346 Answers
SOURCE: GE TV set has picture but no sound model GE09GP106
if you have a schematic diagram you need to look for the mute transistor and replace it, if you only have technical experience
Posted on Mar 10, 2008
SOURCE: Dark Picture
Don't know that it's worth the money, but here's a source for a replacement inverter board (powers the fluorescent tube back light that provides 'brightness'). Manufacturer/designers of screen and back light power circuit, not Polaroid, are at fault . Screen and back light are used in equipment made by others as well, and all suffer same design deficiency :
http://www.lcdpart.com/lcdpartsnet/UI8007S1MSS.html
Posted on Oct 24, 2008
SOURCE: naiko n1003 lcd tv has a fault - no backlight
unplug from mains, remove back cover, remove rectangular silver casing near the top.unscrew circuit board which should have TDK on it.on the underside of this you will find dry solder, just a general clean of this will be enough. done one today..
Posted on Sep 08, 2009
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
Need a manual for Naiko TV model N1003
that problem is usually cause of bad capacitors on the power supply,,It is commonly bulged on the top.
Apr 13, 2012 | Televison & Video
There`s picture but there`s no sound. how can I fix it? Thanks
try check the connection of the wires or try to check if you lock the mute button..
Sep 08, 2010 | Starlite Skyworth SLC1551AW 15 in. HD LCD...
Naiko n1003 lcd tv has a fault - no backlight
Jul 19, 2009 | Televison & Video
I lost the picture on my Sharp LC-20DV20U LCD HDTV. sound is ok
check your heater voltage coming of your flyback transformer going to your crt board.
Dec 19, 2008 | Sharp LC-20DV20U 20 in. LCD HDTV/DVD Combo
No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
Nov 22, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
DVD sound a problem but is playing ok.
try changing your dvd audio settings to stereo
Nov 12, 2008 | Toshiba SD-2800 DVD Player
SANYO TV MODEL CM20SP8S CHASSIS AC3-A20
try to fine tune your tv using the remote control, or, if you had knowleged in electronics adjust the sound IF transformer using a wood stick or plastic don't use a metal in adjusting the IF
Sep 01, 2008 | Sanyo AVM-3259S TV
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
DVD playback no playback
Sounds like the scart lead is not in straight. Scart connectors have the audio pins at one end, and the video pins at the other. If the lead isn't in straight then you often get sound and no picture and vice versa.
Check the connection by pushing the scart lead in securely. (Both DVD and TV end of the lead)
Failing that could be a dodgy lead.
Mar 17, 2008 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
