Sata power supply with ide only mother board?
I have a power supply with Ide and Sata cables i installed it to a mother board that never had sata before. Since the power supply has sata and hooks into the mother board could i add a second hard drive thats sata not ide??
  • 721 Answers
If all the motherboard has is IDE connectors,then you can with an add in card. To do this you need to run the installation floppy during a fresh windows installation when it prompts for 3rd party scsi or raid drivers. I'd take the easy road & install a slave drive on the IDE or run an external hard drive in a usb port. Or the ultimate option,build a system using a board with sata on it. Prices are way down on hardware in general,but it's not going to stay that way.
Posted on May 17, 2010
2 Suggested Answers
  • 1043 Answers
SOURCE: sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Posted on Mar 25, 2010
Install sata disk
From what I was able to find it looks like the board is set for IDE Interface connections for the hard drives. But you can make it accept SATA Drives by adapters that plug into the Power Supply cables that go into the hard drive.
I'll show some links below that will show you the adapters you will need.
The link below shows the Cable that would plug into one of the power supply cables and go into the SATA Drive to give it SATA Interface.
http://www.ebay.com/itm/New-4-PIN-IDE-Molex-To-2-X-15-Pin-SATA-Power-Adapter-cable-Fast-From-USA-/270963453066?pt=US_Drive_Cables_dapters&hash=item3f16ae2c8a
The link below shows you the cable you need that will supply the Power to the Sata Drive. It too plugs into one of the cables that come out of the Power Supply and goes into the Sata Drive.
http://www.ebay.com/itm/New-4-PIN-IDE-To-Serial-SATA-Power-Cable-adapter-/270693224712?pt=US_Drive_Cables_dapters&hash=item3f0692d108
May 10, 2012 | Dell 3E851 Motherboard
Hello.. i have a asus p4pe x mother board and i wanna know wat power supply will i need...
this will depend on HARD DRIVE whether ide the ide will have 40 pins or sata the sata will have 8 copper slat type also PSU power supply unit ide or sata power connecters these days they usually supply both next MOTHERBOARD if has ide and sata plugs the ide will be a flat ribbon type with 40 pin plug ends the sata will be 8 copper slat type usually a bit thicker
most power supply units will fit but to make absolutely sure you could take some measurents inside you computers frame to make sure it will fit also you might need to get a heavy duty with plenty of wattage if you have added more ram another hard drive or a bigger one or any other devices cd/dvd drives then you will need more wattage to boot up
hope this helps
6 PCI slots, supports Socket 478 processors up to 3-GHz, two IDE, on-board sound.
Cons: Only supports one diskette drive
The Bottom Line: Good for building a modest system. It is still useful today. Reliable performance. 6 PCI slots make is very expandable.
molex to sata converters
ide lead which will locate itself by the blank
http://www.amazon.com/gp/customer-media/product-gallery/B0001Y8UI4/ref=cm_ciu_pdp_images_all
molex 4 pin power lead
Jul 28, 2011 | ASUS P4PE-X Motherboard
How do i install a wdeads hard drive? where is the power supply (4pin Molex)?
I'LL TELL YOU UPFRONT i HAVE ONLY INSTALLED SATA ON A NEW SYSTEM SO MY ANSWER MAY NOT BE CORRECT IN ALL SITUATIONS
Question is vague. Are you replacing a drive or building a new system? SATA drives have a dedicated plug on the Mother Board. Of course you already know you can't replace an IDE with a SATA without an adapter (Ebay has them for about $8) or the Bios is incompatible. The power is on the Motherboard and does not have a connector from the power supply like an IDE has.
Feb 20, 2011 | Western Digital WD15EADS 1.5 TB SATA Hard...
I have a an INTEL Motherboard Model DH55HC. I am installing a basic Internal DVD writer (DVR-A18M) Interface ATA/ATAPi-7. I have the power cable from the POWER SUPPLY in the correct plug. I attach the...
That motherboard doesnt support ATA it supports upto 6 SATA devices which is actually better and faster. You will need to take your DVD/RW back and ask to swap for a SATA and also make sure you buy a SATA cable and good thing is these are actually cheaper and faster. Its actually a very nice motherboard dont be disappointed. Cheers from Scott and plz vote
Jan 24, 2011 | Intel DH55HC Motherboard
Mar 25, 2010 | Computers & Internet
I want to install a 2nd dvd burner. But I don't know how to hook it up. My new pc does not have the ribbons like my old one does.
If your 2nd DVD burner is on IDE interface, you may need to get an IDE to SATA cable. Please refer to the picture below as to how it looks like:
Oct 29, 2009 | Compaq Presario 5000 PC Desktop
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Jun 28, 2009 | HP Pavilion a705w PC Desktop
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Feb 21, 2009 | Generic Memory (RXD639) Serial ATA...
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Sata, ide
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
Sep 30, 2007 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
