Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
    Problem Solver:
  • 5 Answers
Hi, in addition to what FWilkerson has said: behind the brew group there is a sort of triangular piece of plastic with a similar shaped hole in it. It has a small drain at the bottom that can be clogged very easily. The piece is glued fairly loose to the rest of the machine. I carefully removed the part to clean it thoroughly. Its function seems to be to funnel a little waste water into the wast water tray. Of course you can also clean it by not removing it. Once removed, you can glue it back on, or as I did, leave it unglued for easier cleaning once in a while. In that case make sure it stays in place when re-inserting the brew group.
Posted on Feb 13, 2016
    Problem Solver:
  • 3 Answers
Take the brew group out from the machine and look inside the machine.espresso grinds will build up inside the area before it goes into drip tray (under distribution spout). Clean it out with a small pick and water. It is plugged up, causing water to bypass drip tray and run on counter top.
Posted on Jan 07, 2013
    Problem Solver:
  • 13 Answers
Try changing the water inlet seal under the water tank (part # NM05.006)
Posted on Apr 22, 2011
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna leaks coffe from under the machine.
1-Try changing the seal of the water inlet under the tank (part# NM05.006)
2- Check the o-rings from the water tubes coming in and out of the boiler.
Oct 19, 2010 | Saeco Vienna De Luxe Espresso Machine
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna leaks CLEAR water from under the machine. A tiny amount of coffee makes it through to the cup
The leaking is from the water pipe coming from the boiler thought the solenoid valve to coffee group. Their are many points that this leak can be so the only way to find it is to run the machine completly open without the plastic sides. The most posible postion is the plastic hose conected on the coffee group and some times you will have to place it back in position very easy.
Good luck.
Remeber to vote for this answer.
Feb 24, 2010 | Saeco Vienna De Luxe Espresso Machine
I have water leaking from under and I cannot see where it is from. I have taken the brew group out and cleaned but it still appears.
try this:move brew unit and you will see white brew valve,clean inside sometimes coffe stuck inside and dont draining water from valve in tray
Aug 20, 2009 | Saeco Vienna SuperAutomatica Coffee...
The machine leaks watter... vienna de luxe
Hi there!
This is most likely a seal that has failed.
These are replaceable and sold through parts suppliers.
Have a look at these pages, then determine if it is this seal that is causing the problem, then replace it.
http://www.shop.partsguru.com/product.sc?categoryId=122&productId=282
This will help in future too -
http://www.partsguru.com/user/DOs%20and%20DON'Ts.doc
If this assists to a solution, Please rate this as Fixya! Thanks.
Jun 19, 2008 | Saeco Vienna De Luxe Espresso Machine
SAECO Magic Roma SUPO13 sn#163830
yes there are parst available but it sounds that the boiler has a leak. You can get a gasket set for it but it aint an easy fix
Nov 12, 2007 | Saeco Vienna De Luxe Espresso Machine
You can download a manual at www.cerinicoffee.com
Jun 10, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
537 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
