Question about Sony Cyber-Shot DSC-W7 Digital Camera
Camera says turn the power off and on - Sony Cyber-Shot DSC-W7 Digital Camera
  • 455 Answers
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Posted on Oct 21, 2010
Camera will not come on, it says "turn the power
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa.
Jun 19, 2011 | Sony Cybershot Dsc-w290 W230 W220
Turn power off and on again appears on the screen
Turn the Power Off and On again error message is displayed when the Lens in the Camera is stuck is affected by a malfunction. Try turning off the power and on again. If the issue persists, try performing a power reset.
To power reset the Camera; turn off the Camera and remove the battery pack.
Allow the Camera to remain without power for 60 seconds.
Then, reinsert the battery and check if it helps.
You may also try INITIALIZING the Camera.
To Initialize the Camera, press the On-Screen key.
Touch MENU-->SETUP-->SETUP 2-->INITIALIZE-->OK. Initializing the Camera will change all the settings back to factory reset.
Thanks for using FixYa
KenSolutions
Dec 06, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
Turn camera off and on again -- fried in outlet
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
May 22, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
My Kodak M1063 digital camera will not turn on no power at all
Kodak EASYSHARE M1063 Digital Camera My Kodak M1063 digital camera will... Answer my camera will not turn on no power at all.
Feb 13, 2010 | Kodak EASYSHARE M1063 Digital Camera
Black screen
Turn the power off and on again message is displayed when the Lens mechanism is stuck or when there is an internal malfunction. To resolve the issue, try turning off and on the power for few times. If the issue persists, try power resetting the Camera.
To power reset the Camera, remove the battery from the Camera. Press and hold the power button of the Camera for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery to check the operation.
You can also try Initializing the Camera by selecting the INITIALIZE option from the SETUP1 Menu of the Camera.
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber camera
The Camera is displaying the Turn the power Off and On again message when the Lens in the Camera is stuck or when any internal malfunction happened.
To resolve the issue turn the power off and on several times. If the issue persists, try power resetting the Camera. To power reset the Camera, remove the battery from the Camera.
Press and hold the power button on the Camera for 30 seconds.
Remain the camera without power for 60 seconds and re-insert the battery.
Also try resetting the Camera back to factory default. Press the RESET button located at the lower right corner of the control buttons using a sharp pointed object.
Good Luck
Nov 19, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Camera won't turn on
I am assuming that the power does not go on or it immediately turns off as it is turned on.
Try the docking station or the 3.3 AC adapter to the camera. Plug that in to live power. If you hear the lens motor (by default the lens is retracted to closed position when plugged to AC power), then the camera is operational. If not, there is power failure with the camera.
If the lens motor work, then try to turn the camera while plugged to AC power. If it turns on, then there is something wrong with the battery or with the chamber. If the camera does not turn on, then check the button board for a bad power switch.
Check the LCD closely under a bright light when you do this test. You may see a faint a flash of display that disappears. I have not figured out what causes this. This would mean that camera power supply is working but nothing is telling for the camera to stay on.
Aug 02, 2008 | HP Photosmart M407 Digital Camera
Powering off
Lens mechanism isn't good to work properly so camera shut down the power. Try to tap the lens/ camera while power up.
Jun 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
M527
my camera lens doesnt work every time i turn it on the screen stays on and then the lens error: M527-22 error comes up can you help me
thanks
Feb 25, 2008 | HP Photosmart M527 Digital Camera
When a camera is inoperable or fails to function, or an error code appears in the liquid crystal display (LCD)
Follow the steps below in the order presented: Perform a power reset on the camera. Performing a power reset on the digital camera will normally correct issues such as the camera locking up or not turning off. When the power reset is performed properly, the camera will prompt you to update the camera’s date and time. This is an indication that the memory has been cleared and no further reset time is required. The power reset procedure must only be performed on a camera that has been running on battery power. If an AC power adapter is being used, the power reset procedure does not apply. This is due to the fact that the internal capacitor is fully charged. To execute a camera power reset, perform the following steps: Turn off the Digital Camera. Remove the Compact Flash Card or Secure Digital Card, if one is being used. Turn on the Digital Camera. CAUTION: To avoid damaging the camera, ensure the shutter button is not pressed during the following steps. Turn on Live View on the rear LCD. CAUTION: Care should be used when performing Step 5 to ensure that the camera is not dropped. Open the battery door and remove the batteries with the camera turned on. Re-insert the batteries after five minutes have elapsed. Turn on the camera. The camera should request an update for date and time (with the exception of the HP Photosmart 120 and 912 series cameras). Format the memory card. Navigate to the delete menu which varies with each camera, and format the internal memory and/or the memory card. CAUTION: Reformatting the memory card erases all of the files that are stored in the card. All photos, scripts, and miscellaneous files are deleted permanently. To preserve the existing images, use a spare card or a card that is already formatted.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Sony Cyber-Shot DSC-W7 Digital Camera Logo
223 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
