Actually, you will not find a driver on Siemens driver website because according to Siemens, the 4100 Ethernet model works with any Ethernet equipped PC, regardless of operating system.
Just ipconfig in command prompt and you will get the default gateway and you can actually get the config page to configure the same. Good luck.
You need the audio Drivers.
Go here: http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2647
This is the support site for the Gateway Computers. There wasn't a listing for the E-4000 so i used the E-4100, it should work just fine.
Download the most recent Audio Driver and install it. Restart your computer and that should fix it.
Hope it was helpful.
Hi rbrown454. That file is for your HP printer. Go to hp.com and click on support and drivers and download the latest driver for your printer. While it's downloading go to add/remove programs in Control Panel and uninstall ALL HP software. Do not restart, wait for the software to finish downloading and restart. Then reinstall the software you downloaded from the internet.
In case you have the CD, reinstall the CD but make sure you uninstall ALL HP Software.
I hope this helps. Please do not forget to rate and provide positive feedback for our fast/free support today. Thank you :D
You're going to have to reinstall Windows. Back up your data and reinstall from scratch. Your Operating System, your software, your printer, your camera and everything else associated with it.
When you mess around with the registry, you're messing with the core system. Unless you know what you're doing then you can troubleshoot.
Next time backup your registry and then work on your registry.
Don't forget to vote for me and give me a good rating and let me know how everything turned out.
Yes it can be done, just follow this http://www.vandomburg.net/installing-windows-xp-from-usb/ But since your hard disk is a SATA and XP doesn't support it out of the box you will need to also add to the install stick the correct SATA driver. And since you are doing that you should add all the other drivers.
if have driver file just go to win xp folder and run the setup and later on go to add printer wizard and try to add printer and choose have a disk option and browse for samsung driver folder and install the inf file from the folder and get install.
Yes, we used to connect to the fax machine to print via parallel cable, but our new laptop computer does not have a parallel port, so we connect via USB now to use the Brother 4100 Intellifax as a printer. It prints very nicely. We downloaded the driver from BrotherUSA.com http://www.brother-usa.com/Downloads/
and clicked on Fax Machines, then our Intellifax 4100e, then View Download and selected our operating system and language. Just a tip - When you decompress the download, in the location to decompress to, add a folder to hold the files named Brother4100 or something like that, then when you add the printer, select that folder as your "Have Disk" location. Hope it works well for you.
to get the required driver.just go to the site driverguide.com and search for the driver.by the way u have to create an account.create an account as free user and search for the driver.
