Question about Canon IMAGERUNNER 9070 Copier
TONER SMUG ON THE SIDES OF COPIES
How do i stop this
  • 31 Answers
Sounds like you are having a fusing pressure problem. I would call out a tech and get him to check out the Fixing unit area.
Posted on Jun 09, 2010
I have e brother 7840w. I changed toner and drum. After that the pages of a copy came out dark in both sides of paper. Who could help?
You may need to pull the toner out and turn it end-to-end several times to distribute the toner evenly. The excess toner on the prints may go away after a few more copies.
Jun 16, 2015 | Brother Office Equipment & Supplies
White lines on both faxes and copies
clean the scanner, which is the .5 inch thick piece of glass that the ppr runs over as is is scanned
Nov 19, 2013 | Brother IntelliFax-2820 Laser Fax
Didn't find the waste toner
the waste toner is part of the process unit. it takes about 45 to 50 thousand copies to fill.
please be careful when you clean it, it is actually 2 units that is joined by a small plastic pen on both sides
remove the process unit from the machine. place it in front of you
the toner is nearest to you, then follow the drum and main charge and at the back is the waste toner. one screw loosen a triangel type cover on both sides. tilt the unit to the side and let the waste toner flow out. you can motivate it by lightly tapping on it.
Jan 20, 2011 | Kyocera Copystar CS-1820 Black and White...
I have just change my toner because the toner was low. and now it is giving dirty copies. I not sure why. But i have shaked the toner wiped and blowed inside the printer. and the same thing is...
print like 10 copies of something
stop it after 2 copies complete and when some copies are half way through
open the machine and check all the copies to determine exactly where the dirty prints are being formed
usually its the fuser where the toner is melted to the paper
it could also be the transfer roller this can be removed and cleaned with lint free cloth (DO NOT TOUCH THE TRANSFER ROLLER with fingers only toch the outside gears)
try those first
Jan 19, 2011 | HP LaserJet 2420 Printer
could be a number of problems that would require a technician, you may need to call one in but as a temporary solution, if you are copying/printing A4 the try A4R or from portrait to landscape. this may help temporarily.
Mar 25, 2010 | Canon IMAGERUNNER 9070 Copier
I want now what's Common faults in Aficio 2035
THe main problems are toner spill form drom/dev units ..the transfer on the right hand door will have to be emptied every few months. the paper tray paper stops need to be checked as they come out of place and cause paper jams if not set in place..cahrge rollers can be troublesome if not cleaned every coulple of months and may cause dirty image at the sides or lines on copies..dust on laser **** glass can cause faint on sides of copies.. the fuser stripper fingers tat guide the paper need to be checked for toner under the points to stop paper jams in fuser and the lower guide plate entrance to the fuser needs to be cleaned off every now and then to stop crinklin of paper...apart from that good machine
Dec 17, 2009 | Ricoh Aficio 2035 Copier
Printer has stopped printing copies even with a new toner and drum. Help!
Try the old one back in it? does that work if so Faulty unit take it back
Apr 23, 2009 | Sharp AL-1661CS All-In-One Laser Printer
Makes copies but leaves a streak of toner on the sides ofthe copy
Drum unit is most likely the problem, but you can confirm that, by removing it, and seeing if it has toner streaks on it, after making some copies. If so -replace.
*Please Rate me ;)
Mar 24, 2009 | Sharp AL-1641CS Laser Digital Copier
Toner low???
How is the copy quality? Are copies light? If so then the toner hopper is not adding toner to the developer assembly in which case you must call a tech. If the copies are fine then the toner sensor is dirty or faulty and must be replaced.
Jul 11, 2008 | Canon 3045 Black and White Copier
Canon d760
there are 2 possabilities for this
1 the drum unit is worn
2 the upper fuser roller/film has worn out
a visual check is needed to determine the cause
please get back to me if you require further assistance
Thank You
Jun 20, 2008 | Canon imageCLASS D761 Copier
old marine
old marine
