Question about BenQ a@Touch M101 (99.Q1988.CFU) Mouse
I have a moakuo gateway usb mouse but my pc wont recognize it!...is there a driver that i can download? i have checked my device manager and all my usb hubs are working
Free driver download for logic world precision optical mouse
world precision throwing me off
according to amazon
logic world mouse of any type
dont require a driver
if USB computer should automatically pick up the driver
check device manager and see what mouse driver is being used
if wireless .......even if you .have you lost the driver disc
computers will recognize the usb plug
Mar 31, 2017 | Optical Mouse Computers & Internet
I need a manual
James: I could not find one for you either. However, I do know that on my own computer, I can't switch a mouse without restarting my computer or it does not recognize it.
May 25, 2015 | Pixxo MA-9EG5 Black 2.4 GHz Wireless...
Wired mouse sometimes lights up but even when it does it does not work pointer
These optical mouse do not work on a shiny surface. Try using it with a mouse pad or place the mouse on a piece of paper.
Nov 27, 2012 | Gateway USB Optical Mouse MOAKUO 7010867R...
Damaged USB Port
Ok I think the best method to "Fix" this would be to get your self a 4 - 5 port USB card, they are, real cheap, insert it into a spare slot, inside your PC, and install the drivers, if any, and use that one. And simply ignore the other one all together.
Feb 18, 2010 | Gateway Essential 400 PC Desktop
My logitech mouse wont move
You need to install the driver for your logitech mouse to work.
If your mouse is not recognized then follow the following steps,
To work around this issue, try one of the solutions below:
  1. Unplug the USB device. It is possible that the connection is not secure and has become loose. This is one of the most common reasons for an error in detecting a USB device.
  2. Use the Device Manager to scan for new and recently installed hardware. From the start menu, select the 'Run' option. In the pop up box, type in Devmgmt.msc and then click 'Ok'. From the 'Action' Mmnu, click 'scan for hardware changes'. This will make Windows recognize any new devices that are installed. Now, close all device managers and control panels. Now see if your computer will read the USB device.
If that doesn't work, here is another option you can try:
Disable power management of the USB hub. To disable the power management on the USB hub, follow these steps:
  • Click Start, and then click Run.
  • Type devmgmt.msc in the Open box, and then click OK.
  • Expand the Universal Serial Bus controllers' node, and then follow these steps for each USB Root Hub that is listed:
  • Right-click the USB Root Hub and then click Properties.
  • Click the Power Management tab.
  • Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
Jun 03, 2009 | Logitech Marble Mouse Trackball
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Keyboard, mouse, front USBs,DVD recorder not working
It sound like your USB Ports is the problem. Go to the Hardware manager delete the USB Ports and then shutdown and power back up.
The system then should reinstall the USB Ports and associated drivers. If not the USB Ports were probably fried by the power outage.
Mar 30, 2009 | HP TouchSmart IQ770 PC Desktop
Laser mouse light won't come on when is used to
If you have a USB mouse, try it on a friends PC or laptop.
if it works there then check your USB (Universal Serial Bus Controllers) in the Device Manager...
right click My Computer
select Manage
select Device Manager
from here you can check you "Mice and other pointing devices, and your USB controllers
Good Luck!
Mar 29, 2009 | Gateway NMZ-500SE Notebook
Gateway g4010 Mouse drivers and USB problems
try reinstalling the motherboard chipset drivers again. sometimes that solves a hidden issue.
Feb 14, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Mouse not being recognized
Hello Narin,
Check the USB properties if there are some errors at Control Panel> System> Device Manager> USB device. Install the compliment CD driver for USB devices. Also try placing the mouse into other USB port(s). Update your OS as necessary for device patches and if there's a need to install driver for the said mouse please install then.. Hope thos helps.
Best regards,
Rosener Guyano
Feb 14, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
BenQ a@Touch M101 (99.Q1988.CFU) Mouse Logo
99 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
