Question about Bosch 24 in. SHU43 Built-in Dishwasher
Change a white door to stainless??? can I
I want to change the white color to a stainless door/panel buttons, handle
I have SHU4 3C02UC17 what do I need to do to accomplish this?
thanks in advance.
  • DGenovese Apr 09, 2008
    I have the same issue with the sme dishwasher - changing the white panel, buttons and handle to stainless steel. Are there any tricks to doing this yourself?
    Thanks.
    Novelist:
  • 130 Answers
Okay here we go. The SHU43C05UC/17 is the stainless model. The parts needed to change over to SS are 1) 431828 SS Facia cost 72.80. 1) 417981 power switch button 15.40. 1) 426062 program buttons set 5.40. 1) 214750 SS outer door panel 101.50. 1) 426063 lid (fits inside the handle area) 3.90. As you see it will not be cheap to change over to a SS dw. These prices are from Bosch's Quick Finder website. Hope this helps.
Posted on Apr 26, 2008
  • Jeff York
    Jeff York Apr 30, 2008
    Hello DGenovese sorry about the question I asked as it didn't refer to this here about changing the panels. When you open the door there on the outer edge on the inside of the SS inner door liner is 6 (torx 20) screws holding on the outer door panel. There will be 2 blocks inside there that will fall off the hinges, however they only go on 1 way. Now across the top of the inner door is 4 (torx 20) screws that have to be removed & look at the left and right side 1 screw (torx 20) per side. Now the control panel drops down. Release the clips on the lower facia and it comes off. i will see if I can add the service manual (general) to Fix Ya. Have a good day.
    Champion:
  • 246 Answers
Have you looked at www.applianceart.com? they have several options that may be easier for you. I think there may be some options that will do EXACTLY what you are looking to do at a fraction of the cost. Gie it a try.
Posted on Sep 09, 2009
    Problem Solver:
  • 8 Answers
No tricks!
You've simply bought the wrong appliance.
Stainless only available on certain models
Unfortunatly youre stuck with a white dishwasher.
Posted on Apr 25, 2008
I have a Kenmore Refrigerator/freezer, model # 59673503201. The freezer door was dented, so I ordered a new one, which arrived without a handle. I removed the 8 screws on the inside panel and attempted...
The handle is held by screws and butter clip. You removed the screws,but also release the clips.If in case the clips break during removal,then you can replace the clips too.The cost of each clip is $2.There are two clips in total.One clip on each side of the handle.Once you release this clips the handle should freely come out.To see how the clips look.See the fig below:-- helpmech_57.jpg
This clips are called butter clips or mounting clips.To order this clips if required.Please click on the link below:---- http://www.repairclinic.com/PartDetail/Mounting-Clip/1023807 -------------- If you want door handle removing diagram for your refrigerator: Click on the link below:--- see the diagram:--- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/M0307112-00001.png ---------------- If you require new handle then click this link directly:---The cost of new handle is $21.----- http://www.repairclinic.com/PartDetail/Handle/1070320 ------------ Also for more help,if you require,freezer door disassembly diagram.Please click on the link below:--- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/M0307112-00004.png ---------------- This should help.Thanks.Helpmech.
Jan 26, 2011 | Refrigerators
Need a part number
The part number for the door handle on this model dishwasher is either:
W10142998 (STAINLESS)
W10142999 (BLACK)
W10143000 (WHITE)
The handle is listed as item 14 under the "Door and Panel Parts" section at searspartsdirect.com. The part numbers are based on the color, so make sure you use the correct number to get the matching handle for your dishwasher. The kit inlcudes all the mounting hardware as well.
You can check these others sites as well to compare prices:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Are white front door dishwasher replacement panels available?
yes but you would be better of removing panel and taking it to your nearest powdercoater may be cheaper cheers
Nov 05, 2009 | Dishwashers
My 15 year old ge profile refrigerator door handles are worn to the under material. I want to paint the refrigerator and change the handle color to stainless and black. Do you have such a thing? Model #...
you should check out www.applianceart.com, they have vinyl and magnetic solutions that can cover your appliance in a new color or pattern. They even have a stainless steel option for refrigerators too.
Sep 06, 2009 | GE GSH22JFR Side by Side Refrigerator
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Would like to change white color to black or stainless
If your model number is correct you can find door panel parts at appliancepartspros.com. Type in your model number and look under Section 3, Door and Panel Parts for item 4. There are several different colors available including black and stainless. Make sure you select the correct part number. I hope this helps you.
Jul 19, 2009 | Whirlpool GU2455XTS Built-in Dishwasher
Changing my door panel for another colors
Well you can get a stainless steel panel cusot-made at www.applianceart.com. They have a lot of options. One of them is stainless. The options are a vinyl sticker, a magnet, static cling or the actual stainless panel. Most are $39 and the metal is $99 I think. Good luck.
May 27, 2009 | Kenmore 14249 Dishwasher
White to stainless
Black, white and bisque seem to be the only colors available for the double convection oven. Might be possible to find the cooktop, but it's hard to know for sure without the model number.
In my experience, it's often not economical to switch to stainless steel as stainless steel panels can be extremely expensive (I've seen a freezer door on a side by side fridge sell for over $850... Just the freezer door!)
Mar 05, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Front panel color
I have the use&care guide for this unit. It explains how to change the panels - I also notice in ebay that you can order generic stainless ones. I'm going to remove my white panel to install the stainless.
Jul 28, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
818 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
