Question about HP Pavilion DV9620US Notebook
No display everything turns on windows loads but no display
    Scholar:
  • 69 Answers
We can further isolate the issue by connecting an external monitor to the notebook. If the display is fine with the external monitor, this clearly indicates that the issue is related to the LCD screen. Otherwise, it is due to the some other internal hardware.
You may follow these steps to connect the notebook to an external monitor.
1. Turn Off Computer.
2. Connect the monitor cable from the monitor to the monitor port on
the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
* Switching the display to the external monitor
Press FN + F4 to toggle the display between the Notebook display and
External monitor.
Posted on May 16, 2010
Monitor - Display problems
There may be a power supply failure in your monitor
May 30, 2013 | ViewSonic VA712 17" LCD Monitor
I need drivers for LD9900UP-GY for Del Computer running Windows 8
windows 8 usually runs everything or connects to internet & downloads it, try searching online for the driver manually & down load & run it.
Jan 30, 2013 | Logic Controls Pole Display 9.5mm 2x20...
I have a problem.that is, whe i switch on my laptop with a hibarnate system that time display show white,after booting display back to windows.when i shutdown it,after that when again i on it.that time...
is this a 100% hibernate only failure? questions?
tell what the PC does good and bad, then we can answer.
NO OS stated, XP ?
first off for hibernate to work the following must be ok.
1: XP? not infected as all are.
2: all HP drivers that came with it new, still present and loaded.
it came with XP or VISTA
see that here. load all drivers, and it can work.
Id avoid hibernate totally, on such and old PC< unless
reloading everything from scratch, is ok. for you. I would.
Use the F11 key at power one to reload windows.
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-v6700-notebook-pc-series/3629671/model/3651450
Aug 20, 2017 | HP Compaq Presario V6700TX Notebook
Make sure its not set in external mode press Function Key and usually f5 the one with 2 monitors
Mar 25, 2010 | HP Pavilion DV9620US Notebook
Monitor does not work, computer starts up, dell prompts load, windows prompts load then screen goes black. i can hear everything loading but no display.
connect an external monitor on your machine and check if display is ok on the external monitor. if yes, try to re-install your video driver and check if display is ok on your laptop.
if both doesnt have display (external monitor and laptop's display) i suspected your lcd display is faulty.
Jun 30, 2009 | Dell Inspiron 6400 Notebook
When i turn it on it starts to load but windows will not load
Try "F8" and then safe start ,,could be you need to reload windows though.
Jan 19, 2009 | Everex StepNote LM7WZ Notebook
Will not display output from Computer
Probably the video resolution or the monitor Refresh Rate (eg: 50/60/75 Hertz) is set too high in the operating system, which over-drives the monitor electronics and it is unable to display anything.
If you restart the computer manually (hold in the power button for 5 seconds, the computer will shut off, turn it back on again) you will see the normal BIOS and Windows startup display on the monitor, but then as Windows completes it's startup it returns to the error message you see.
To fix this, restart the computer manually and start the computer in Safe Mode. To do this press F8 just before the computer starts to load Windows, and choose Safe Mode. Once in Safe Mode, you should see the monitor working correctly.
Now restart the computer in Normal Mode and everything should be fine.
Dec 23, 2008 | Westinghouse LCM-19v1 Monitor
Just loaded software on my Windows Vista Laptop for the Nikon L16 digital camera------everything loaded fine but cannot get it to transfer pics from camera---it is not "seeing" camera when I have...
Software for camera in a required in Windows computers
And as you have Vista it is like not compatable anyway.
Remove the software and simply plug the camera in
Windows will recoginise it as an extra drive in 'My Computer.
or
Windows camera/scanner wizard will display
Aug 20, 2008 | Cameras
Again WINDOWS ME
Click Start, click Run, type MSCONFIG (hit enter), click the button labeled “Extract File…” For the name of the file you want to restore, type EGA.CPI. Restore from your Windows Millennium CD (if your CD is your D: drive, type: D:\WIN9X). Save File In: C:\WINDOWS\COMMAND. (Found that in msconfig (international) pointing to display data file
c:\windows\command file EGA.CPI).
May 09, 2008 | Computers & Internet
I have just bought a fujifilm Finepix S700 digital camera. I have installed the CD-ROM, but am not able to load pictures to my PC. The computer displays the following message:"Please wait while...
Okay...we can figure this out.
Does your computer have enough memory and all the requirements to run the software?
You may want to make sure you have the latest service pack from Microsoft for Windows ME.
Also click the link below for Fuji's site to make sure you have the latest update for their software.
http://www.fujifilm.com/products/digital/download/index.html
After you know these are up-to-date, then start from the beginning. Turn off everything wait a few minutes and then turn on the computer. Wait for Start Up programs to load. Then follow instructions in Owners Manual for loading FinePixViewer.
Hope this helps. (blasted technology!)
Let me know.
Feb 29, 2008 | Cameras
HP Pavilion DV9620US Notebook Logo
411 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
