Question about Maytag Performa PAV2200
Runs fine untill it gets to the spin cycle then it hums like a burnt out motor
  • Maytag Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machineruns fine untill it gets to the spin cycle then it - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 17, 2010
Washer runs until it gets to the Rinse cycle and stops... You can tell it wants to work because there is a faint humminb sound, but doesn't.
If the washer will agitate it's not a motor problem, capacitor or a broken motor coupler. It's either a loose wire connection on the start circuit or failed contact in the timer. When you say that the motor hums during spin, that would indicate that the motor has run voltage, but it has no start voltage. It needs both start and run voltage in order to get the motor started and running. The start voltage gets the motor started, and once started all it needs is run voltage to keep it running. The only difference between agitate and spin is that the polarity is reversed in order to start the motor in the opposite direction.
Jan 10, 2011 | GE 3.2 Cu. Ft. 14-Cycle Super Plus...
Whirlpool quiet wash plus DU920GWGD4 runs after cycle is finished. Just hums, no blades turning. No sign of leak... If I turn circuit off then back on it is fine until it runs a few times again. ...any...
Water air lock problem. Check your inlet for free flow.
Pour water from the front and mostly it will ease the problem. After this cycle it should work OK. The humming is due to water starvation in the motor.
Mar 30, 2010 | Dishwashers
GE Washer WWSR3090T8WW does not agitate
Sounds like a transmission failure to me?
Good Luck !
Feb 10, 2010 | GE Washing Machines
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
My blower motor will not start. it hums and gets very hot. i can spin the wheel with no resistance gmp075-4
Assuming you are spinning it when the motor is humming, if the motor runs after spinning it it could be the run capacitor (replace) or open/broken start winding in motor(need new motor). Humming should indicate the motor is getting proper voltage. If motor does not try to run by spinning then open run winding in motor (replace motor).
Aug 30, 2009 | Heating & Cooling
Kenmore stackable washer/dryer 417.97802792 won't drain
its your brushes on your motor or the motor itself but my guess is the brushes replace and enjoy
Jun 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Motor is humming loudly.
Motors hum, and your right, it could be no worse than normal.
I would be suspect that there is a gear stripped in the gearcase, since this is a direct drive washing machine.
Reassemble the motor back onto the washer. Run it through a cycle manually (rotate the timer by hand) until the motor turns, then look to see if it's turning. If it is, or even more so, if it pumps water out of the tub, then it is probably the stripped out gearcase.
Reply with you findings and more advice.
Jan 23, 2009 | Kenmore 24872 Top Load Washer
Washing Machines Logo
245 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
