Question about Samsung HLP4663W 46" Rear Projection HDTV
No color Reception seems to be ok but the picture in black and white.
  • Samsung Master
  • 8,457 Answers
This tv have a colors wheels it dead,it spinning off of it axis.That why u getting black&white picture.Hire a tv tech. to change the colors wheel.Because it hard to change the colors wheel,u never done it before.Have to take out alots machanicals parts before even can get to the colors wheel to change it.
Posted on Jun 19, 2010
Color went in and out, no i only get fair black and white picture often grainy
I'm assuming here that this tv is being used for analogue reception because on digital you either get a perfect picture or when the signal is weak enough, nothing at all (common when trying to use rabbits ears or in poor reception areas). Assuming analogue then, when the signal is weak (grainy or snowy picture) the colour (called chroma) is automatically turned off because grainy colour is unwatchable. This is normal. Solution, a better aerial to provide a stronger signal.
Jan 20, 2011 | Akai PDP4206EM Television
Hi, how do you take black and white pictures on the Olympus µ Tough 3000 ?
you can't shoot in black and white but you can take a picture and change it to black and white.after taking your picture use the color edit option at playback.arrow right or left to choose the picture then press the ok button.use the right and left arows again to select desired color and press the ok button again.this will save a seperate image copy of you original only in black and white.
hope this helps.
Jan 09, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
No color
Dmd Module will cause this problem.#BP96-0067A
#BP96-0678B Price $270.00 Encompass Parts did not list any in stock 1-800-638-3328 but they might can order one. Look on Ebay Under Electronics type in the number I gave you sometime you can Find Parts their alot Cheaper then what companys want.
Encompass Parts Distrubtion has Free Service Manual you can Print out for these TV
If you need anymore help just let me know, I will be glad to assist you.
Mar 25, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Distorted picture. changes from color to black and white.
Hi, this is a bad main board that is causing this issue you are experiencing. simply replacing this board will fix this issue.
Click Here
May 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Have a sony cybershot, and for some reason it wont take pictures in color, just black and white, and i cant seem to find a setting to change it to color.
put your camera mode in t "P" setting then go to menu & you should see color or pictue options to switch the color back to color....i have a cybershot dsc-w55 idk what u have but try that .... GOOD LUCK !
May 12, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Have an RCA console, color, 26" screen. Over 30 years old. Hooked up to cable and DVD player. Overnight the color disappeared and reception is black and white. Did color guns go out?
If you can see white, then all the CRTs are functioning. Make sure that the channel is set correctly. If the DVD is sending out channel 3 and the TV is set to channel 4, you will see the picture, but in B&W, Check that first. Let me know if that does not resolve it.
Thanks,
Dan
Mar 06, 2009 | RCA Televison & Video
DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Samsung HLP4663W 46" Rear Projection HDTV Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
