Question about Garden
05 42''MTD 18.5 HP B&S Intec OHV White/Blue Smoke/oil in exhaust
I Have a 2005 mtd 42'' riding mower with a 18.5 b&s intec ohv engine that started to emit thick blue/white smoke occasionally. After a few bouts of this over a season the mower ended up sputtering and stalling out. Since then I tried to turn it over and it spat large amounts of oil from the exhaust pipe. Now it won't turn over at all when it tries to it sounds like metal on metal grinding. I tried to manually turn the head ''guess thats what it's called'' and it rotates to a point but never makes a full rotation as if something is blocking it. I'm looking to see if the engine is completely shot and if so is it rebuildable and worth the time/money to rebuild it. Any pointers that you all can give me to determine the exact issue would be helpful. I'm not a mechanic but I am technical so I'm sure I can follow directions. Thanks Darryl.
  • 36 Answers
First check the oil and see if it is way over full and if so the fuel may be leaking by the needle and seat on the carburetor and overflowing into the engine crankcase, if it is over full you must drain all oil and remove the filter then install new 30 weight oil and filter, before trying anything else, after changing the oil turn it over again and see if it can make a complete revolution and if so you will then need to either install a new needle valve and seat or have one installed. If the dead stop it makes when you turn it over sounds like a hard clank it is probably a broken connecting rod. and i would be on the look out for a good used engine replacement
Posted on Mar 15, 2017
SOURCE: mtd riding lawnmower won't run
my mtd lawn mower wont start . when I turn the key there is a buzzing soung where the battery conectors are near the shifter but the starter is hot and getting juice
Posted on Jun 13, 2009
SOURCE: NEED WIRING DIAGRAM FOR MTD 14.5 HP OHV I/C RIDING MOWER
try going to www.tulsaenginewarehouse.com/drawings/allwiring.pdf
Posted on Aug 29, 2009
jdlipscomb41
  • 157 Answers
SOURCE: MTD Riding Mower with 21 hp OHV 1/C
the valves need adjusting
Posted on Sep 18, 2009
  • 468 Answers
SOURCE: 05 42''MTD 18.5 HP B&S Intec OHV White/Blue Smoke/oil in exhaust
From the sounds of it, you've at least lost the rings in your engine. I'm not sure of the circumstances, but it almost sounds as if it had too much oil in it. These small engines lubricate themselves by throwing oil all over the inside of the engine, and if too much oil is in there, it won't throw it. They will also burn oil off if it gets into the cylinder from the level being too high. This would give you your bouts of blue smoke. The grinding noise that you describe may or may not be an issue, but here's something you need to try. First, make sure that the oil level is exactly as it's supposed to be. Then, remove the spark plug and see if you can get it to turn over. If the cylinder's full of oil, it won't compress, and it won't let it turn over with the spark plug in. Next, get a can of starting fluid, and spray it in the spark plug hole. Crank the engine over with no spark plug in it. Repeat the starting fluid, cranking cycle until you don't see any more oil coming out. Leave the spark plug out, and let it sit for a couple of days to evaporate. Clean out the plug or replace the plug in the meantime, and then reinstall and attempt to start. It'll probably smoke like crazy for the first 15 minutes, and then be fine after that. This is the number 3 problem I've found when repairing small engines; with #1 being flooded, and #2 being having water in the fuel. Leave a comment if you find that it won't move even if you remove the spark plug, and I can discuss more with you then about your options.
Posted on Mar 25, 2010
huffman49
  • 235 Answers
SOURCE: 13.5hp tecumseh ohv engine with mtd tractor.
check the ground...good luck
Posted on Apr 10, 2010
What's the valve gap set on a yard machine 139 ohv mtd push mower
3 to 5 thousandths of an inch on a cold engine.
Search Results
Lawn Mower Repair Valve Adjustment - YouTube
? 4:44
https://www.youtube.com/watch?v=NjzX-PUjKmo Mar 7, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on a Briggs OHV engine. The valves need to be ...
? 5:06
https://www.youtube.com/watch?v=j77Y5iwXTzg Mar 6, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on an overhead valve lawn mower engine. The valves ...
How to Adjust The Valves On An OHV Lawn Mower Engine ' Hunker
https://www.hunker.com > Home Hacks & Answers > Garden & Lawn > Lawn Mowers Sep 19, 2009 - How to Adjust The Valves On An OHV Lawn Mower Engine. By Lisa ... Many lawn mower engines use overhead valves. This means, the ... Turn the screwdriver to either increase or reduce the clearance between the setscrew and the top of the valve. Tighten ... Will Mothballs Keep Snakes Out of the Yard?
valve gap set on yard machine 139 ohv mtd push mower Google Search
Aug 14, 2017 | Mtd Garden
Overfill oil
Sounds like the engine is tired. Blue smoke is oil burning. Hard starting is oil on the spark plugs and/or low compression. This also can be due to someone adding too much oil.
Sometimes, the carburetor Needle valve hangs u pa bit and the Crank case oil gets mixed with gas so now the oil level is high. Too much oil in a motor is bad too, that would cause theblue smoke too.
Jul 20, 2013 | Yard Machines 11A08MB006 22Inch 139cc MTD...
I have a briggs & strat 17 hp ohv intec model 311707 on my craftsman lawn m. it was running then with a large puff of smoke it quit. now the starter runs it with no compresion, removed the s p (oi
does the engine when it is turning over sound normal? does the engine have any compression at all or is it just not as much? sounds like a burnt valve
Sep 07, 2012 | Measuring Tools & Sensors
Cant find motor Model number on Bolens MTD 2005 Riding mower 15.5 hp I/C OHV
Per your own question that is the model # just use the 13AM762F765, There should have been a 2nd set of numbers and those would be your Serial number 9 digits followed with (000005) which is year built. I have exact same mower
Mar 04, 2012 | Briggs & Stratton Garden
42" MTD riding mower. Won't start. Had a tough
White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned.
Read more: http://wiki.answers.com/Q/What_can_cause_white_smoke_from_the_exhaust#ixzz1ZTQwS4Al Hope this helps
Sep 30, 2011 | Mtd Garden
Does a briggs 18 hp twin 2 have a oil filter its a late 90's model mtd riding mower
Most likely yes. It will look like a car oil filter. It looks like a round can that is screwed to the engine.
Mar 17, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Mar 25, 2010 | Garden
What type of oil does a OHV 17.5 HP Kohler engine; number of zerk
10w-30 oil. The only grease fittings I know of are on the front wheels and axles.
Jun 22, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
