Question about GE GSL25JFR Brushed Steel Side by Side Refrigerator
Water issue in the GE Refrigerator.
I have the same issue on a two year old GE side by side refrig. I tested the water pump/filter/cirucit by disconnecting the tube from the blue connector loop just below the freezer door. When the knob is pressed, water comes out of the disconnected tube in good force. So this means the pump/filter/circuit are all good. Now only problem is water does not climb from just below the freezer door to the dispenser area. Any help will be appreciated.
Thank You
Mohan Prabhu
jmp@rocketmail.com
Put a hair dryer on the door for awhile. Mine freezes up
Posted on Apr 02, 2008
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
My refrig is not cooling and the water dispensor is not working
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8dfhs
May 20, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
My ~ 3 year old GE 23' side by side keeps shutting
no ck's for the main board but is sounds like it need one / replace it as they have many updates / the newer bords are much better . mm.
Dec 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our side by side is leaking water in a puddle on the left front corner (water dispener side) off and on. 9 year old refrigerator. Refrig/Freezer and ice/water working well.
I'm going to give you a lot of information on one page please choose thye part that most defines your situation and I will be here to assist you, Please rate me, Thanks, Sea Breeze
Click Link Below
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water filter
are you looking for a replacement filter for your refrig or looking to locate its whereabouts in refrig???? 11 years ago its possible, sorry very probable that a water filter did not come equipped with refrigs.if so it would be in top right corner mounted on ceiling insider refrig.
Mar 11, 2008 | GE Profile TPX24PBDCC Side by Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
GE GSL25JFR Brushed Steel Side by Side Refrigerator Logo
74 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
