Question about Dell E228WFP LCD Monitor
Stuck in power save mode
After I put my passcode in the screen went blank and now it wont come on any more and it is stuck in power save mode. What should i do
  • 11,361 Answers
More likely to have failed power supply/invreter board.
http://www.lcdrepair.us/E228WFPc-inverter-power.html
Look for bad caps first (leaking/bulging tops).
Possible lamp assemblies failed also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 16, 2010
Why am I getting a blank screen after login?
In case you are using Win OS try to start in save mode. First the Bios is activated after pushing the power button. If you see the screen from the Bios start pushing F8 which brings you to the save mode start up. When your PC starts you can shut it properly by leaving the save mode. Try to start up the pc again in normal mode. I hope it will fix you problem
Aug 26, 2014 | Toshiba Satellite Computers & Internet
STUCK IN NEED TO RESTORE
If it has the iTunes logo and a picture of a USB cable then it has to be restored. If you're stuck at a lock screen or if it is locked out because of failed passcode attempts, then you'll have to force recovery mode. There is no bypass for this & you will lose all the data on the device. To force recovery mode, plug it in to the computer. Hold the home button and the power button at the same time. Keep holding until you see an apple screen. Release the power button but keep holding the home button. When you see the iTunes logo & USB cable you're ready to restore. This will set it up as new with no passcode. Any data you saved to your computer can be synced back.
Apr 04, 2014 | Apple iPod touch
Trying to reset password - tried following link provided
No Link provided
Which Link ???????.....
Is it for an iphone???....
Every Apple iPhone has the ability to use a "passcode"--a four-digit number that must be entered to bring the iPhone out of standby mode when it has been locked.
If you are the first owner of the iPhone and have forgotten the passcode that you initially entered, you can simply reset the passcode by connecting the iPhone to the computer that was originally used to activate it.
However, this does not help if you purchased the phone used and are not the original owner.
Put your iPhone into recovery mode to restore the iPhone and clear the passcode.
Connect the iPhone to your computer using the USB cable.
Hold down the power button on the iPhone.
The screen will change asking you to use a slider to power the unit off. Use the slider.
Press the power and home (bottom-center) buttons simultaneously.
The unit will power back on. After a few seconds, the screen will change to a warning triangle. The iPhone is now in recovery mode.
Launch iTunes and click on the iPhone icon on the left side of the screen.
Make sure that the "Summary" tab is selected and scroll down until you see the "Restore" button. Click "Restore."
Click "Don't Back Up," then click "Restore."
The iPhone will be reverted to its original factory settings, which will clear the passcode.
Note that the Restore process will also remove all other data from the iPhone, including music, contacts, notes and saved e-mails.
Sep 15, 2013 | iPhone Apps
stlmeuzyk, Internal "switch-mode-power-supply"/"ccfl-inverter-supply" will probably need to be refurbished (repaired). Use Dell warranty first if valid option! Try monitor on different pc or verify your pc is working properly with old, but known-good monitor. If your E228WFP unit is still not working then you or qualified electronics technician will need to tear-down monitor to evaluate and repair the ac to dc power supply printed circuit board. Before you do anything read my fixya profile to learn flashlight test that every ccfl back-lit lcd monitor owner should know how to do and interpret the results of test. The basic design and operation of your E228WFP isn't any different than any other brand!!! Read the older solutions in my profile and follow the links you find there. Then do additional comment if need more info. Good luck with the repair. 12fixlouie
Mar 25, 2010 | Dell E228WFP LCD Monitor
Iphone
You can restore your iPhone if you don't know the passcode this can be done by :
  1. While your iPhone is turned on connect it to iTunes via USB cable
  2. Once iTunes has recognised the iPhone turn your iPhone off and DO NOT disconnect it.
  3. Turn your iPhone on while pressing the home key
  4. When the Apple Logo appears let go of the power key but keep pressing the home key until the screen goes blank
  5. This will put your iPhone in recovery mode and your PC will recognise it as "iPhone DFU mode"
  6. Once this happens go back to iTunes and you will have the option of restoring your iPhone.
Aug 30, 2009 | Apple iPhone Smartphone
Connection problems
you will need to restore it then.put it in DFU mode while connected to the computer. to do this, hold the home and power buttons for ten seconds and then let go of the power but keep on holding the home for 10 secs. the screen will be black and nothing will show up. go to itunes and restore it from there
Mar 25, 2009 | Apple iPod touch
Restore still wont let me in
If you know how to put the phone in DFU mode your itunes will see it as in recovery mode and allow it to be restored.
If your planning on unlocking the phone for use without an iphone account, It's super important to restore the phone with firmware from 2.2 5G77 back. Don't restore to 2.2.1
Get the firmware here
For putting in DFU Mode
Plug the usb into the iphone and not into the computer.
1) turn your phone all the was off. (with the red slider)
2) Hold the home button for 5 second and then press and hold the power button for 7 seconds (Holding Both buttons down)
3)let go of the power button and keep holding the home button for an additional 27 second. your screen may go blank. don;t worry
now plug your usb into the computer with iTunes open.
iF it mounts in itunes it will say it's in recovery mode. press the shift key and press restore with you mouse choose the iphone firmware you downloaded from the link and restore.
I believe this solution will help, good luck!
Mar 01, 2009 | Apple iPhone Smartphone
Sansa wont work
Once you have it in recovery mode, create a file called "sansa.fmt" and put in on "16mb" (Which is what your sansa shows up as in My Computer when it is in recovery mode). Once you have put the file on the "16mb" disconnect the cable and allow the device to restart unlocking it before it boots back up.
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
Windows XP in Power Save Mode with blank screen
PC DESTOP ?
PC LAPTOP???
WITCH ONE DO U HAVE???
Nov 18, 2007 | Microsoft Windows XP Home Edition
Dell E228WFP LCD Monitor Logo
247 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
