Question about Sony W595a Cell Phone
My phone won't turn on at all. I take out the battery and the sim card but nothing happens...this is the second time this happend.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 95 Answers
Try and boost it by charging using an universal charger first. maybe the battery is too low
Posted on Jun 06, 2010
New unlocked cell phone won't turn on
Hey, same problem. Push and hold the hangup button. It will prompt to insert sim , but I only have one. The phone works. The website and the manual are useless. Just gotta play with it, I guess.
Mar 06, 2013 | Cell Phones
Puk code won't work on prepaid sim
The PUK number relates to the phone not the card. Have a look under the battery.
Jun 09, 2017 | Cell Phones
Water damage
1. Remove the back cover of your phone. To do so, you will have to press down on the silver latch while sliding the cover off toward the top of the phone.
2. Remove the battery from inside of the phone. Be sure to place it somewhere where it will not be damaged. Locate a silver hatch; this is where the SIM card is stored.
3. To undo the silver hatch, slide it in the direction that says "Unlock." Then, flip it upwards so that only one end of it remains attached to the BlackBerry. Carefully remove the SIM card.
4. Replace the SIM card after a few seconds. It should fit back into its place in the exact same way you found it. Lock the silver hatch by laying it back down over the SIM card, and then sliding it the opposite way you had unlocked it before (to the side that says "Lock"). Put the battery back in as well (by fitting one end at a time). Replace the cover (make sure the silver button latches).
5. Turn the phone back on. The "SIM Card Error" message should be gone.
Aug 17, 2012 | RIM BlackBerry Curve 3G 9300 Cell Phone
I have an SciPhone i68 4G. It is a dual sim phone. I tried putting my T-Mobile sim card in with a Vectone sim card and I found that I was having trouble with the battery. It would turn off even when I was...
TO SEXYBABE008 -I HAD THE SAME PROBLEM YOU ARE HAVING. THERE ARE TWO SLOTS FOR THE SIMS CARD- THEY ARE ON TOP OF EACH OTHER- IF YOU ARE ONLY USING ONE SIMS CARD- PUT IT ON THE TOP SPOT WHEN INSERTING IT- THIS WORKED FOR ME- THE BATTERY HAD NIOTHING TO DO WITH.
Mar 01, 2011 | Cell Phones
Phone saying insert sim card have inserted sim with credit on but nothing happens
Try power cycling for the phone. Please follow the steps below:
1. Remove the battery from the phone while it's turned ON.
2. Remove the SIM card.
3. Leave the battery and the SIM card out for five (5) minutes.
4. Put the battery and the SIM back and turn the phone ON.
If same problem occurs, try using another SIM to isolate the problem. If same thing happen after trying another SIM, then the phone needs repair. You may need to contact the manufacturer.
Have a great day!
Nov 02, 2009 | LG KG800 Cellular Phone
Sim card rejected
Two possible things have happend:
A: the SIM card is blocked by your provider.
Hot to test:
Try the SIM card in another phone. If it doesn't works there, call your provider.
B: the phone itself has blocked the SIM. This shouldn't happen with just little settings chaning... there has to be a major misuse happend.
This could maybe disabled by starting the phone with another SIM-card inserted and the security settings should changed. There's a setting that's checking the SIM (no idea at the moment what the name of it is). This should be disabled. Than the SIM-card of you should work again.
Sep 19, 2009 | Nokia 1600 Cellular Phone
Cuts off during call
Alot of times this is when the battery or SIM card for whatever reason gets loose inside and for a second or two loses contact. Believe me, I see it everyday. What happens is sometimes when the factory sends the battery new with phone in the box, it is a bit to small. The door or sleeve that holds the SIM card in (for phones that take the sim cards)do not actually hold the SIM card in-they only hold it partially in-the battery does the rest. So if the battery comes loose, alot of times so does the SIM card. Try this, take your SIM card out, along with the battery, look for anything that might be loose. Then put the SIM card in, then take a piece of paper underneath the battery. This will help the battery keep contact, and is just a test to see if this solves your problem.
Jan 22, 2008 | Motorola Mobility RAZR V3
Emergency calls only
I've received the same error on a couple of occasions. Most times the problem has been fixed just turning off and then back on. If not, turn off, remove the battery for one or two minutes then replace and turn back on.
Oct 28, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Phone says "charge complete" but then just dies
I took your suggestion and replaced the SIM card, but the difference is I managed to locked it in tightly. It worked.
Aug 21, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Sony W595a Cell Phone Logo
155 people viewed this question
Top Sony Cell Phones Experts
richie46
m_suresh
Level 1 Expert
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
