Question about Kitchen Ranges
Oven won't light on bake
I have a Maytag freestanding gas cookstove. The oven won't light on the bake setting. We think it may be the electronic ignitor? Are they very expensive, and can we put it in ourselves?
    Novelist:
  • 184 Answers
IF THE IGNITOR GLOWS WHEN YOU TURN ON THE OVEN, BUT DON'T GET ANY FLAME, IT IS MOST LIKELY THE IGNITOR. THE COST OF IT IS AROUND 50-75 DOLLARS.
TO REPLACE ONE, YOU MUST GAIN ACCESS TO THE OVEN
BAKE BURNER BY LIFTING OUT THE BOTTOM PAN OF THE OVEN. THEN REMOVE TWO SCREWS THAT HOLD THE IGNITOR TO THE BURNER. FOLLOW THE WIRES DOWN TO THE CONNECTOR PLUG. SELF-CLEAN MODELS WILL BE BEHIND A PANEL BEHIND THE STORAGE DRAWER. NON SELF-CLEAN MODELS WILL BE BEHIND AN ACCESS PANEL DOWN IN THE BROILER AREA. DISCONNECT THE PLUG AND REPLACE THE IGNITOR IN REVERSE ORDER.
PART NUMBER 12400035 MAYTAG.
Posted on Mar 31, 2008
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
Hi, We have a Maytag gas range. I believe it's a mgr5710adw the number is wore off and unfortunately we didn't write it down in our manual. Anyway, when using our bake burner sometimes it will...
IF the model number you have listed is what you belive to be correct thepart number for that gas safety valve is 74006427 this link i have included isa picture of it. Does it look EXACTLY like the picture if yes it will work http://www.repairclinic.com/PartDetail/Gas-Valve-Assembly/74006427/895773
GENE
Sep 23, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Maytag oven model mgr5770 oven hard to light and doesnt keep temp even when it does gas stops lighter still glows?
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
I hope this helps
Gene
Aug 01, 2011 | Maytag Kitchen Ranges
The electronic panel related to oven and clock does not work. code 5ab appears on the display
Hello, welcome to FixYa.
Your range has somehow been set in "sabbath" mode ( for the Jewish calendar I think...not the metal band, lol ) If you have the owners manual turn to the section referring to this an it should instruct how to reverse the setting.
All ranges do it somewhat differently, so I can't say exactly how on yours. This example is generic, hopefully it works. If you are unsuccessful let me know the exact model number and I'll see if I can locate it.
Hold Clock pad for 5 seconds to activate Sabbath mode. Hold Clock pad for 5 seconds to disable Sabbath mode.
Oven must be in BAKE mode before enabling SABBATH. "SAb" displays and flashes for 5 seconds. All pad inputs are disabled except for CANCEL and CLOCK pads.
This mode disables the normal 12 hour shutoff to allow operation of the bake mode for a maximum of 72 hours.
Good luck. Thank you for choosing FixYa.
Regards,
Macmarkus :)
Jul 18, 2011 | Maytag Gemini 30" Self-Cleaning...
I have a Maytag gas stove model MGR5730BDW. The oven won't light. The broiler works just fine. The bottom ingiter glows orange and gets hot but the burner won't light.
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
273 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
