Case gears black steel 480W power supply Model # BKS480 I need to find a wiring diagram or what component is at the THR1 location on the circuit board as this component has burned out in mine And I am trying to figure out what type of component I need to replace it very comfortable with soldering the new component in just need to figure out exactly what it is
SOURCE: Power Surge damage. Suggestions on which part to replace.
I would start looking at the power supply, it's usually a separate board where the a/c line plugs into. In many cases i have seen that the problem you described is from a damaged power supply, sounds like something is shorting causing the power supply to continuously come on and off. I would first check the capictors to see if any of them have blown, usually cylinder looking and sometimes you'll see an X or a K at the top of the cylinder, if it's blown then the top will be bulging out instead of being flat. If all those look good then there is probably a short somewhere else like in one of the transistors, if so you'd be best to just find another power supply board to replace.
Posted on Nov 09, 2007
worldvet
  • 859 Answers
You probably have a sacrificial diode that blew out to save the rest of the monitor from further damage. The manufacturer should replace it with a refurbished one at little and sometimes no charge (comparatively speaking).
Posted on May 10, 2008
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
SOURCE: power supply for gateway
This power supply has an odd form factor so just "any" power supply won't work.
Posted on Oct 03, 2008
SOURCE: need circuit diagram for bush
Diagrams i am sure as you know are not always easy to come by, at least for free. I see that there are available boards online and a company that will rebuild this model of power board for you in UK. ohmsupplies.co.uk is where it is at. looks like $80
Posted on Oct 16, 2008
I need a replacement Sunbeam/Black Steel 480W Power Supply made by casegears
If it's a standard ATX case, then any power supply is compatible.
equal or higher power output is fine.
so a 500w will still only use the power needed by the hardware.
Mar 20, 2014 | Dell Inspiron 518 Desktop Computer
I need a replacement for my Sunbeam/Black Steel 480W Power Supply made by casegears, seems its been dis-continued. Is there a compatible replacement?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817709010 This is the closest replacement. Ensure the diamentions are the same and it will work fine.
Mar 20, 2014 | Computers & Internet
Under the hood, passengers side, is a male plug with a red and black wire, it has a small plastic strap attached with a hole for a screw in it. What does this hook up to.Thanks for help.
I am going to assume everything on your Jeep works and your check engine light is not on.
Its possible the harness is for something on the 4 cyl engine.
Or it could be for an accessory not used on your model.
It would be tough to find out not knowing what the circuit is for since the wiring diagrams are geared to specific circuits.
Most red wires are power and black wires are almost always ground. There is a red-black that powers the ASD relay in the fuse box.
You might look at other Jeeps in a salvage yard.
Feb 01, 2013 | 1996 Jeep Cherokee Sport
I need to know where the power supply wires to the clock are to be put and where the wires to the fixture need to be placed.
The black power supply wire goes to the #1 terminal (LINE). The black fixture wire goes to the #2 terminal (LOAD). Both white (neutral) wires go to the "A" terminal.
Sep 09, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
I need a wiring diagram and or a color code chart for the wires and plugs coming out of a "Power Tronic" switching power supply model SK-4145DE. 145 watt power supply. Thanks for your help.
Many power supplies have a chart on the side of the case.
Here are the wire colors for an ATX type supply:
RED +5, YELLOW +12, White -5, Blue -12, ORANGE +3.3,
PURPLE +5VSB, GREEN Power On, BLACK -Gnd (common).
Feb 14, 2010 | Power Tronic PowerTronic 145W Switching...
I know the circuit diagram but how do you
If the power originates at the location of the light (or other item being switched) you need a 3-core cable from there to to each switch location.
If the power originates at one of the switch locations you need a 2-core cable from there to the fixture and a 3-core cable to the other switch location. (If the cable to the second switch location is routed through the junction box at the fixture then you only need 4 cores from the first switch to the junction box--three switch wires and the neutral wire for the fixture.)
In all cases described above the ground (earth) wire is separate and not included in the count.
Oct 21, 2009 | Lutron CW-2-SS Claro Two-Gang Screwless...
What is blue wire on ge built in oven for
The blue wire goes to a seperate 15 Amp circuit breaker or fuse.
This breaker should be powered by the L1 (black) supply feed in the breaker box. The circuit supplies power to the display and control buttons. The red and black wires go to a double ganged 20 Amp breaker. Check inside the oven back cover for a wiring diagram.
Sep 07, 2009 | GE Profile 30" Built-In Single Electric...
C.b.radio-power won't come on.(red & black wire show short!)
The fault is probably at either end. Yes, it could have been reversed, but most radios are easily protected against this.
If you are getting no lights or anything when keying mic, then there may be an inline fuse along the cable. As you are getting continuity, open the case up, and look for any evidence of heat at the components nearest the power supply - particularly the protection diodes - Black cylinrical components with a silver band.
You really need a meter or scope to go in much further, and check supply voltages between components and -ve, and downloading a copy of the circuit diagram will help this.
The other main fault is usually the output power transistor - which needs a sink for all the power getting thrown at it. If you remove the antenna, it can quickly overheat and fail.
Both components can be checked in-situ for voltage (or not) but the output can only be tested with a scope.
Of course - the "on" light could have blown, so may be functioning without indications, - but I doubt it.
Also check Mic outputs on the plug to make sure that is working. Some units won't function if this is disconnected.
Jan 08, 2009 | Cobra 29 LTD CB Radio
Schematics or diagram for a 480W PSU
I need a schemetic diagrm D15-1013/diablo ATX 250w Power supply
Thanks Louie.
Dec 18, 2008 | Computers & Internet
Thermal resister need a replacement for thr1fwstansbury@mchsi,com
THR1 is reference designator for the component on the PCB. What is the marking on the component. THR1 is a thermo resistor and is probably a TO-237 outline package. On the black tab part of the device it should have a marking like R100 or PCT with a symbol to represent the manufacture.
Nov 30, 2008 | Diablotek / APower / 420-Watt / Micro-ATX...
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
