My reddy 30 heater will not stay lit after starting I have held the switch down for longer than 30 sec but it just want stay lit
  • 53 Answers
Thats sounds like a thermocouple problem its located right by the pilote light assembly,,,rod shaped object
Posted on May 16, 2010
2 Suggested Answers
  • 9 Answers
SOURCE: my reddy 30 heater will not stay lit
The thermocouple is what tells the gas valve to supply or not supply gas. Several things can cause the thermocouple to malfuntion.
1. pilot light jet is clogged and will not allow the pilot light to reach and heat the thermocouple. Repair by cleaning the pilot light jet out.
2. corrosion on the thermocouple which will also not allow the flame from the pilot to heat the thermocouple properly. Repair by sanding the thermocouple lightly with sandpaper
3. Thermocouple is bad and needs replacement.
Posted on Mar 25, 2010
My reddy 30 heater will not stay lit after starting, I have held the switch down for longer than 30 sec, but it just want stay lit
Mar 25, 2010 | Heating & Cooling
Starts up and runs for 30 sec. and stops.yes it has fuel
find the high limit switch an replace or see if fan runs if fan runs then the limit is bad replace
Mar 15, 2010 | Reddy Heater-30-55,000 BTU Variable
I lights when I hold the button down and goes off when I release it. It is a model for propane and says model 100,104,106,110. reddy heater
You need to hold the button down for 15 to 30 seconds before it will stay lit. If you are doing that, the thermocouple is bad. They are cheap and can be found at any hardware store.
Jan 27, 2010 | Reddy HD30 Heater
Rlp 30 won't stay lit after holding control button 30 seconds
Chk and make sure the thermocoupler bulb is in the pilot flame, If it is, it is defective and needs to be replaced. Easy, inexpensive repair. Good Luck, Ned
Dec 27, 2008 | Reddy Heater RLP100 Portable Forced Air...
Won't stay lit..
I contacted ReddyParts.com and talked with their support department (866-883-9312). They instantly stated "your thermal coupler is bad". They had 1 in stock for 19.99 + shipping. I ordered it and plan to have it installed and tested by next weekend. The model I have is Reddy Heater Propane 35k to 55k (RLP55V).
Dec 12, 2008 | Reddy Heater-30-55,000 BTU Variable
Wont stay lit
Yep, sounds like you got it. Unscrew the fitting at the gas valve and take the thermocouple to a reputable Propane Gas supplier. They can match it up for you or you can order one off the internet.
Oct 26, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Forced air propane heater won't stay lit
two items come into play here - 1) the hot surface cutout and 2) the flame detect Cd cell. Check alignment of the Cd cell or just replace it. The hot surface cutout has two terminals that plug into the two tabs on the millivolt generator.
Feb 06, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
377 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
