Question about HP LaserJet 3055 All-In-One Printer
Error applying setting to driver - HP LaserJet 3055 All-In-One Printer
Error message on stamps.com says: error initializing printer. I have used this printer lots and lots of times and this just started popping up.
ok 2 things either your firmware is outdated or your driver... i do have the same problems due to my driver is not correct...plus when i updated the driver i forgot to set printing orientation and paper size
first go to
http://www.seagullscientific.com/aspx/thermal_95.aspx
scroll down to zebra click download
then install it
you will see 2 printer in your printer and fax in control panel
right click on the LP2844 (not the Zdesign LP2844)
select printing preference
go to page setup tab
choose 4x6 from the drop down menu in(stock)
then apply
also dont forget to go to option to set the darkness uncheck the use current printing setting
go for 12- 14 the default setting is to light sometime might not scan..by usps...
since everytime you updated the driver ...your setting might go on default...that why you'll need to go back and reset the printing pref...
after i did it ...the stamp.com doen't have problem at all
hope this help
http://www.etsy.com/shop/iamyot
Oct 06, 2010 | Zebra LP 2844 Thermal Printer
I'm trying to print a job and when i push the print an error msg come up current software settings not set for USB Ports. I am working on windows vista home premium
You could try to apply the printer driver to USB port:
Start > Control Panel > Printers
Right click your printer icon (name) > "Propererties"
Click "Port" Tab
Put a check mark in appropriate USB listing
Click Add Port
Jan 09, 2010 | Lexmark X2600 InkJet Printer
Epson t88iv error codes 32
Did you set it up using Epson's receipt printer drivers? If so, right click on it and choose properties. Under the PORT tab, check and make sure it is set for proper port (LPT1, COM1, USB, etc). If you make changes, click APPLY, then OK. Then Right click, PROPERTIES, Print test Page. If you can't get test page to print, your wasting your time sending codes to printer.
Let me know if you need more assistance.
Aug 31, 2009 | Epson TM-T88IV Thermal Printer -...
ThinkPad R40 2897 lost all internet. No Wireless, No Ethernet No
check the device driver status of network adopters in device manager .if it shows any error then reinstall the device drivers again.
if you are using WI-FI then reinstall the drivers of your wireless device.
and don't forgot to reboot your system after doing so.
if the problem exsist then contact your ISP.
they will provide the settings if any and i hope you are able to apply setting for the internet connections.
Apr 26, 2009 | IBM ThinkPad R40 2897 Notebook
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
Tv turns on then off
hold the menu and input buttons simultaneously for 5 seconds. the tv will blink an error code
Error Code Probable Cause
12 Normal Operation - No Error Detected
21 X-Ray Protect
22 Short Protect - likely convergence IC failure
23 Loss of Horizontal Deflection
24 Loss of Vertical Deflection
Fast Blink for 70 sec. After AC is applied = Normal - DM μPC is booting up
Fast Blink (doesn't stop) After AC is applied = TV μPC is running, but DM failed to boot up
Slow Blink Set is Off = Normal - Timer is set for Automatic Turn ON
Dec 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Moniter problem
you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows.
Sep 16, 2007 | Computers & Internet
HP LaserJet 3055 All-In-One Printer Logo
447 people viewed this question
Seeker5211
Seeker5211
