Question about Gateway FPD2275W LCD Monitor
AL 1916 s
Hi My Acer AL 1916 s computer screen won't work, it just comes up saying no signal. Do you know how I can fix this? Thanks
  • 99 Answers
When you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem
Posted on Apr 01, 2008
SOURCE:
Acer AL 1916 Ab driver
NO PC stated at all, wow.
NO OS stated, wow, 2. (you skipped the top 2 inputs)
this driver, it is config file (the GPU chip needs driver)
that tells your unstated OS what limits the screen has
1280 x 1024 maximum resolution (this is the limit)!
all you do is go to unstated OS , safe mode and set that to that limit.
and bingo it works. (if running Linux say so )
a very old monitor, old square screen 4:5 legacy,.
most are dead this old.
if running W7 to w10 now, (unstated)
step 1 is make sure PC is web connected first. this allows the PC to find the montor config file at ms.com PnP servers. and work.
this monitor is 10 year old today, 2008 made.
here are your offical (not acer, ask them)
config files.
at ms.com
vista and up supported ONlY
http://www.catalog.update.microsoft.com/Search.aspx?q=%20Acer%20AL1916
try the 12/12 dated version. I would.
all you posted is monitor.
lacking all useful details.
Aug 10, 2018 | Acer Computers & Internet
Acer 1916
Go into control panel, power options, go to hibernate, "top right" and click. Uncheck hibernate box, next! power schemes, " top left " and click, go down lelt side, "system standby " select never from the list and close window. This will prevent your laptop going to sleep, shutdown windows when you are finished.
Apr 23, 2012 | Acer Computers & Internet
AL 1706 troubleshouting monitor wont turn on green
If your monitor shows a yellow light and it won't turn green, the problem most likely lies with the computer. If your computer is not sending a signal to the monitor, then you have a computer problem. One way to test this is to turn the monitor off and the computer off, too.
Turn the monitor on and if it is working, it should display a message telling you that there is no signal. If you see that message, you can assume the monitor is working. If you do see it, now turn on the computer and see if the message changes.
If you turn the monitor on and you get no message, you can assume the problem lies with the monitor itself.
If you have access to another monitor, hook that one up to test the computer output.
You can now either get the monitor fixed or the computer fixed, depending on which one is bad.
May 31, 2011 | Acer Computers & Internet
Hi there. My monitor has been working fine up to yesterday. I have all connections plugged in and i turn on the monitor and then the ACER sign comes up and then it says No Signal. and then the blue light...
Your monitor is fine, the problem lies with your computer. Your monitor is not receiving the POST signal from your computer. I suggest you remove your computers graphics card and plug your monitor cable into onboard graphics, then power up and see if the monitor gets a signal. If it does then it means that your graphics card has stopped working. If you still don't get signal then I suggest you take your PC to your local computer shop and get a qualified technition to have a look at it just in case the motherboard is damaged. You can also try out your monitor on another system just to be sure.
Feb 12, 2011 | Acer X233H 23" Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Monitor lcd acer al 1916 half the screen is white
Theres 2 PCB on the side working one of those is faulty
May 13, 2009 | Acer AL1916W 19" LCD Monitor
Acer Al 1916 W mind of it'e own
you need a new power inverter, better yet a new monitor. I have the same monitor as my secondary.
Jul 21, 2008 | Acer AL1916W 19" LCD Monitor
AL 1916 Monitor Green Light Flashes
I think you have loose cabling somewhere. Try to unplug (and untangle) the video cables and then plug them all back together firmly. If this does not work and you know your machine is booting up properly, you might have damaged the monitor somehow accidentally.
Nov 16, 2007 | Gateway FPD2275W LCD Monitor
My moniters screwed
Sometimes this is due to graphics cards, but most of the time it is due to drivers. If it does not happen when you are using your PC for other things the problem probably just lies with the graphic card, driver, and this particular game or any game similar. Drivers are the most notorious! Check your requirements on the game for graphics cards recommendations! Let me know!
Oct 10, 2007 | Acer AL1916W 19" LCD Monitor
Black Screen on ACER LCD 1916 Monitor
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
134 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
