Question about Yamaha NS-AW1 Main / Stereo Speaker
Broken binding post replacement advice for Yamaha NSAW1 speaker
Greetings I have inadvertantly broken one of the speaker ( Yamaha ns AW1) binding posts and I am now trying to determine how to safely remove same to facilitate replacement. Any tips you can provide would be appriciated
4 Suggested Answers
  • 3567 Answers
SOURCE: powervalve on top is broken. yamaha 250yz cross.
Stuff happens on a race bike. The problem is that it can happen so fast, with your mind on other things during a race, you don't even realise somthing happened. Another bike probably kicked up a small rock and aimed it at your carb.
Posted on Aug 29, 2009
  • 17 Answers
SOURCE: tip of pilotscrew is broken
spot weld a screw to it using a MIG welder, make sure you take the carb off the bike 1st, and that its free from fuel, or vapours, else it will catch fire, once a screw is welded to it, use that screw to undo your other, as they are now classed as a complete screw, it should come out with ease.
Hope this helps!
Posted on Apr 30, 2011
petraman7
  • 1175 Answers
SOURCE: i have a yamaha receiver rx-v371 the speaker imput clamps on the back are broken. Can i use banana plugs?
For the main speakers , Yes, you can use banana plugs. Theyre built for that.
I hope that helps
Posted on Dec 16, 2014
1984 Yamaha venture royale 1200 stuck in 4th gear
Hi, Michael and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Stuck in 4th Gear 1995 Sportster 1200 Harley Davidson Forums
ATV Connection
http://bergall.org/temp/venture/pdf/1983-1985-yamaha-venture-manual-complete-with-wiring-diagrams.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xv-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 20, 2017 | Yamaha Royal Star Venture Motorcycles
Shifter wont shift
Hi, Anonymous and the usual suspects are:
6. Shift return spring weak or broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
yz85 transmission not shifting after bottom end rebuild Yamaha 2 Stroke
Dirt Rider Magazine
YAMAHA YZ85 LC Owner Service Manual
YAMAHA YZ85 Owner Manual
Jan 18, 2014 | 2004 Yamaha YZ 85
Stuck shifter on 1973 yamaha 360 enduro. how do i fix it?
HELP MX250 engine stuck in neutral will not shift Vintage Enduro...
http://www.vitalmx.com/forums/Race-Shop,42/Bike-stuck-in-1st-geat,450813
DOWNLOAD NOW Yamaha DT250 DT360 DT 250 360 Service Repair Workshop Manual... $15
http://mybikemanuals.com/yamaha/yamaha-dt
Mar 20, 2012 | Yamaha DT 360 Motorcycles
1986 yamaha rt 180 stuck in first gear
Hi, B and the usual suspects are:
First dirt bike Yamaha RT 180 issue Page 2
1990 1998 YAMAHA RT180 Service Manual Repair Manuals AND Owners Manual... $10
Yamaha RT180K Owner Manual
Jan 30, 2012 | Yamaha Motorcycles
This 2003 yamaha yz 85 wont shift into gear whats wrong with it ?
Hi, Colton and the usual suspects are:
Transmission Locked In Third Help
Bike won shift stuck in one of the upper gears
Oct 18, 2011 | 2005 Yamaha yZ 85
My Yamaha RX-V563 receiver displays "Check Speaker
Look closely at the rear connector panel of the receiver and look for pieces of stray strand wire that may be touching the speaker A binding post and the receiver chassis. If you are not using strand wire connection to the binding post then check whatever connector type you are using such as banana plug or spade plug for breakage or corrosion, the same goes for the speaker cable itself which isn't always so easy to detect. A few broken strands can cause a problem.
If it is clean, turn off the receiver and disconnect the speaker cable. Check the binding post for tightness; if you can wiggle it then it is broken and needs to be replaced.
Oct 03, 2011 | Yamaha RX-V563 Receiver
I bought a 1981 Yamaha 750 seca and I've had it for about a month. I was riding one day when it started revving really high as I was downshifting when coming to a stop. It is now stuck in first gear....
Hi, 750seca and the usual suspects are:
XJ550 Maxim won shift gears
81 yamaha seca 750 shifting problems
Yamaha XV535 Owners Workshop Manual
YAMAHA XV535 Owner Manual
Aug 23, 2011 | Yamaha Motorcycles
2005 Yamaha YZ85 stuck in fourth gear
Hi, Harjitbasi08 and the usual suspects are:
How to get YOUR Motorcycle out of Stuck Gear
YAMAHA YZ85 Owner Service Manual
Yamaha YZ85G Owner Manual
Jul 12, 2011 | 2005 Yamaha yZ 85
The tweeters in my yamaha NS-515F have blown. Any ideas where i can purchase suitable replacements?
http://www.partsexpress.com is a popular source for loudspeaker components.
Also, are you sure the tweeter's blown, and not a crossover component?
www.mouser.com carries many electronic components that could be used in crossovers.
Dec 02, 2008 | Yamaha NS-515F Speaker
Yamaha NS-AW1 Main / Stereo Speaker Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
