Question about GE WSXH208A Front Load Washer
Ge flw WBH5200J1WW: Keeps randomly clicking door lock and going into pause mode. Now it is not adding enough water.
  • 236 Answers
SOURCE: Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Posted on Feb 16, 2008
SOURCE: GE WBVH6240F
I got the same problem...
Posted on Jul 11, 2008
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
SOURCE: GE washer: door won't unlock
We had the same problem and there is a wiring harness right at the door and I guess over time closing the door or the vibration from the spin cycle worked it loose. It would click and click like it was trying to lock but then the cycle would not start and it would just humm like it was trying to start the water. Make sure before you start to unplug the washer. The harness plug is on the side of the drum right at the door. If you take the bottom panel off and take the bottom two screws out and pull the panel out as much as you can you can see it there on the side. Just plug it back in and you are good to go.
Posted on Jul 09, 2009
carputers
  • 255 Answers
SOURCE: GE ADORA WASHER IS NOT DRAINING AND IS STUCK IN PAUSE MODE
bad pump/motor or bad belt going to pump
Posted on Sep 08, 2009
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
FLW-1920B element tv code for ge remote
Google the model number of the remote for a "manual" which will have instructions
Keep in mind not all remotes will even program for all sets.
Jun 10, 2012 | Olevia LT32HVM 32 in. LCD Television
Need a code for 19 inch Element FLW-1920B tv or a remote.
Check these codes.
003/ 004/ 009/ 022/ 133
0002 0014
Apr 30, 2012 | Televison & Video
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
I need a code for GE URC RM24912 for my Element TV model FLW 1920B
Try this, Turn on the TV,press and hold set-up button until light comes on, then release,the light blinks off once, press on-off or power button repeatedly (up to 300 times) until the TV turns off, press and release enter to save code.....hope this was helpful...
Apr 25, 2010 | Televison & Video
My GE washer keeps pausing itself
The most common problem i have seen is the door lock has failed,but it can also depend on what part of the cycle it is pausing on.The other more common problem is the main control panel has gone bad,
Check to make sure there are no obstructions that would cause the drain pump not to pump out water.
Feb 26, 2010 | GE WSXH208A Front Load Washer
I need ONE FOR ALL remote control urc 3220 code for TV
i need a code for urc3220 one for all remote control
Mar 20, 2009 | Televison & Video
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Feb 16, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
23 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
