Question about Kenmore Refrigerators
I have a kenmoore refrigerator and when I plugged it in in the garage it worked. We then moved it into the kitchen plugged it in and the lights work but the motor or fan is not coming on.
  • Kenmore Master
  • 1,606 Answers
It could be stuck in defrost , but without the model number , I can't tell you where the timer is located . You may also " tap " on the thermostat knob , to see if fan and compressor start ( if so , thermostat is bad ) .
Posted on May 16, 2010
Why does my 3.0KVA transformer keeping tripping my garage electrics but works ok when I plug it into the socket in the kitchen
the wiring on the transformers plug or the wall socket in the garage might be wired wrong. black is hot white is not, 110 v plug
USE a to touch power test light or a voltmeter and compare power from kitchen and garage outlets the plugs wide blade/prong should show no light or voltage when checked to the gound, if it does the wall plug is wired wrong.
hope this helps vote up 4 the=
Jay the pool pump motor repair guy Longwood FL
Jul 01, 2017 | Kitchen Ranges
Why is ice build in my frost free/refergirator, and water dripping into refergirator?
Your Kenmore may not perform well in the garage environment. Since it isn't practical to move it back inside, you may have to abandon the idea of having a second operating unit.
Dec 15, 2013 | Refrigerators
I have the Kenmoore Microwave Hood 721.80402. During this last wave of storms, I was without power for 2 days. Once the power was restored, the microwave will not work. Everything is plugged in and the...
You might try pulling the plug on the unit and leaving it overnight. The electronics may have locked up due to irregular voltage during the failure. There may also be a GFI (ground fault interrupter) on that circuit that has tripped for the same reason. Check the kitchen outlets for a tripped GFI.
Feb 14, 2010 | Kenmore 62622 Microwave Oven
Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
Jun 02, 2009 | KitchenAid KTRC19MKSS Top Freezer...
Only freezer works
Hi: When you plugged it in how long did it take for the bottom to warm? If it was a week or two it might be your defrost heater(frost builds where it shouldn't). It's just a wire in a glass tube like a light bulb, and will be fragile after years of service. When the freezer works and the fresh food dosn't it means there is no circulation between the two. Frost will build up where you don't see it, and it's where the air channel is between the freezer and the fresh food. When moving a ref. it usually is the def. heater. The light bulb is isolated from this circuit so it may just be the bulb (the filament got shook) or the switch. Good luck Jeff
May 30, 2009 | GE J Series 20.6 cu. ft. Top Freezer...
Kitchen lighting problem.
Open neutral. check the fixture/switch closest to the bkr panel that is not working for a bad connection in a wire nut, if not there, move to next fixture/switch closer to the panel
Feb 10, 2009 | Whirlpool Gold Series GI15NDXT 15"...
Freezer will not work due to out side teperature being low
Sorry, not doable. Temp in garage below 50 degrees will cause problems with any domestic fridge or freezer. The soda machines you see outside actually have heaters in them so they can work in the winter. Hope this helps!
Jan 06, 2009 | Hoover HCA351K Bottom Freezer Refrigerator
Changed filter, red light flashes, not making ice at all
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
KENMOOR 59672253200
I was out of town and the top part, the refrigerator part lost the coldness. The freezer which is on the bottom is working ;just fine.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
63 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
