Question about HP Pavilion dv6000z Notebook
Keyboard my keyboard the numbers on my letters are locked so i cant type any letters on that side of the computer I was typing e mails. switched user and went to go into do some document work and neither numbers nor letters would work. I have a Compaq presario
  • Steph 2 Dec 01, 2008
    working on a thinkpad laptop- no num lock- getting the numbers instead of letters on right hand side of keyboard
    Problem Solver:
  • 10 Answers
Update ur keyboard drivers , and also see that u r using the language which related to ur keyboard, by default language for india is U.S.
Restart computer and see it will work. If possiable reinstall ur operating system (repair).
Untill u can use software keyboard which is persent in every
operating system(On- Srceen Keyboard).
please rate my answer
Posted on Mar 31, 2008
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Unlock the Caps on Computers
The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files.
This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words.
When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function.
Open a word processing program.
Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document.
If lower case letters appear in the document, Caps are successfully unlocked.
Proceed if the text is in All-Caps.
Hold down "Shift" on the keyboard. Press the letter "P."
A lower case "p" appears in the document. Release the "Shift" button.
Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T."
Press "Enter" on the keyboard.
The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off.
Restart the computer to save the setting.
Enable the Caps Lock Key
The "Caps Lock" key is loved by some and disliked by others.
The key turns all letters into capitals as you type.
While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized.
The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock."
If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key.
If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels.
Updating the registry for the keyboard will enable the "Caps Lock" key.
Open the Notepad program.
Type the following:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=-
Select "Save As" from the "File" drop down menu.
Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window.
Type "enable.reg" without quotes in the "File name:" field and click "Save."
Minimize all open windows to view the desktop.
Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning.
Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
Manually Update the Registry
Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor.
Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings.
Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion.
Disable the Caps Lock Key in Windows
Your computer's Caps Lock key has likely only collected dust since you first brought the machine home.
The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often.
Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key.
Download the registry file necessary to disable your Caps Lock key.
You have the option to disable your Caps Lock key or change the key to a number of different keystrokes.
For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key.
Double-click the registry file you have downloaded.
A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry.
Select "Yes" to install the registry file.
Restart your computer, once again, to complete the registry change.
Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer
The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately.
When this mistake occurs, usually you must correct some text errors and your time is wasted.
If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key.
Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window.
Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control".
Double click on "Keyboard Layout" to open the folder.
Open the "Edit" menu and choose "New" then "Binary Value".
A new file will appear on the right side of your screen with the file name highlighted.
Type "Scancode Map" for the new file name.
Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button.
Close the "Registry Editor" by selecting "Exit" from the "File" menu.
Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Hope this helps
Nov 05, 2012 | Computers & Internet
Numbers take precedence over letters on shared keys
On my keybard I have a FN function key and F13 locks it. It lights an indicator.
Carl
Jan 11, 2010 | Acer NSK8458AN Keyboard
MY TOSHIBA R ONE HUNDRED WONT LET ME TYPE NUMBERES
Go to control panel and scroll down to regional and language settings. Go through each tab, including the keyboard tab and make sure all of them say either United States or English - (United States)
Sep 15, 2009 | Toshiba Portege R100 Notebook
Hi, I've got 2 eeepcs, with identical problems,
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed.
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Fn key plus and probably the Scroll keys, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Aug 13, 2009 | ASUS Laptop Keyboard for Asus Eee PC
The num lock key controls letters on regular keyboard.
Let Number key stay off then you could use normal 1234567890 that is between QWERTYUIOP and F1-F12
May 22, 2009 | HP Pavilion DV9920US Laptop
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Gateway laptop keyboard typing incorrect letters
Windows has support for many input-languages, e.g., for keyboards made in France with accented characters,
and for the DVORAK keyboard layout (which is a complete
rearrangement of the letters on the keyboard for maximum
typing-speed).
Go into "Control Panel", and "Regional and Language" and click the "Language" tab, and switch to the "USA Keyboard".
Feb 18, 2009 | Gateway 7001433 Keyboard
Keyboard trouble
ok in the keyboard there is fn right. Hold FN+Number lock (num lk) then it should transfer back to letters
Jan 02, 2009 | Computers & Internet
Keyboard
HI,
The problem could be that you have the Fn key on the lower left side of the keyboard remains depressed. Also try switching off the Num Lock . That should solve the problem.
Apr 12, 2008 | Dell 0Y3740 Keyboard
Keyboard
Solution #1, Go to RUN type in 'msconfig'.
In startup uncheck MotiveSB.
Try to reinstall the keyboard driver. Solution #2
  Sounds like it may also be dirt or some spilled soda.
-- Had the same problem after an OJ spill. --
If you feel comfortable about removing the keyboard, disconnect all the wires and cables, then give the keyboard a thorough washing. Then let it dry overnight.
If that doesn't sound like something you want to attempt, then you will have to take it in to a computer shop.
Oct 29, 2007 | Compaq Presario 1200XL104 Notebook
HP Pavilion dv6000z Notebook Logo
190 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
