Staples shredder spl 1506x no power when plugged in
Spl 1506x no power when plugged in
4 Suggested Answers
SOURCE: Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Posted on Aug 09, 2008
  • 7 Answers
SOURCE: Have a Staples shredder SPL 1506X and need to find
no there is not
Posted on Jun 11, 2009
  • 300 Answers
SOURCE: Automatic switch does not shut off after shredding
These shredders have a "paper in" sensor. This is either optical or mechanical.
Sounds like the sensor is blocked and therefore "thinks" there is still more paper left, and this is why it keeps going.
Before you do anything UNPLUG THE SHREDDER.
The sensor is located about in the middle and at the level of the blades.
If it's mechanical, you should see a little finger, else it is electronic.
Shine a light in the area and you should be able to spot where the blockage is.
A shot with compressed ais usually gets rid of the offending particles.
After you're finished working on it, set it back securely on the basket and plug it in.
Posted on Feb 14, 2011
Where can I obtain a repair manual for a Staples SPL 1506X Shredder
You can't. You take it apart yourself, you find the cogs inside are plastic and shattered and you can't get replacements, so you have to buy a new one.
Apr 09, 2016 | Staples Office Equipment & Supplies
How to oil shredder staples spl-1506x?
You can buy commercial products, or run some wax paper through your machine periodically. The wax will not gum up like oil and attract dirt.
Jul 13, 2014 | Staples Office Equipment & Supplies
Parts manual for SPL-TXC122A
I need a plastic gear for the Staples SPL-TXC122A Does anyone have one?
Apr 06, 2013 | Staples TXC122ACC Cross-Cut Shredder; 12...
Spl-1506x shredder only runs in reverse
Daniel:
Unplug the shredder... Take the top off and turn it upside down. Use a screwdriver to take the lower cowling off and look at the motor. If the mounting area where the motor sits looks melted at all, the machine is toast. If the motor mounting area looks good, look at the slot where the paper is inserted... there should be a sensor (that "sees" the paper when you insert it) at the paper slot. Check to see that the sensor isn't damaged.
Nov 11, 2012 | Staples SPL1506X (CrossCut) Shredder
Staple Model SPL-XC200D Paper Shredder, During the
Fixya does not sell parts and cannot identify sources.
Jul 18, 2017 | Staples SPLXC200D Shredder
Automatic switch does not shut off after shredding on Staples model SPL-1506X shredder.
Feb 13, 2011 | Staples SPL1506X (CrossCut) Shredder
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Shredder problem
Call us at Fellowes Customer Service 1-800-945-4545 On Monday between 7am and 7pm Central Standard Time
Feb 23, 2008 | Fellowes DM15C Shredder
128 people viewed this question
jasbo
jasbo
