WinXP installation error
When installing my Dell with Windows XP I just frequently got an error message of Error code 4 could any one be having a solution tried putting a different cd - rom drive seen a few changes but still can't get to the solution I still can not complete my Windows XP installation
  • darryl coueslant May 11, 2010
    I had a similar problem, when stup was running it would not copy some files, during installation if a file failed i opened cd drive and closed it again for it to search for file again, when it came to doing it again 6 months later had the same problem, i replaced the xp cd and was fine, even if the cd does not look scratched it may have errors....
    Sergeant:
  • 349 Answers
This problem can start when you have a ram problem or the drive is about to crash.
take ram out & clean the golden edge both sides with rubbing alcohol or a pencil rubber.replace the ram
when you start the install again, do not use the partition that is on the drive now ,go for format and set up new partition,windows will check the hard drive for errors before it starts to install,
hope this helps you
good luck let me know how you go
Terry
Posted on Apr 02, 2008
Error code 6be showing wen installing winxp
This error can occur due to any of the following:
The Catroot2 folder is not correctly deleted during the installation.
The random access memory (RAM) configuration is not compatible with Windows XP.
One or more of the RAM modules on your computer do not work correctly.
Nov 09, 2013 | Microsoft Windows XP Professional
While instaling windowsxp i had a problem and gives a error code
One of the files on the XP installation CD must be damaged or corrupted.
Try to restart the installation process again.
If it produces the same message, you might have to use another installation CD.
Thank you for using Fixya,
Kenneth.
Feb 14, 2010 | Microsoft Windows XP Professional With...
How to solve pci.sys error during reformating of the hard drive
You have two ways to solve the problem of "Pci.sys Is Missing or Corrupt"
Error Message When You Start Windows.
1.Booting with WinXP CD to access the Recovery Console’s Repair option,
and then copy from WinXP CD the missing or damaged Pci.sys file to
Systemdrive:\Windows\System32\drivers folder , Exit and Reboot.
start the recovery console and type:
set AllowAllPaths = true
expand d:\i386\pci.sy_ c:\windows\system\drivers32 /y
If you don't type
set AllowAllPaths = true you can't access the windows folder.
2. Booting with WinXP CD and then perform a Windows XP Repair Reinstall
of the currently installed system.
If you need detailed assistance post with details of your Operating system
[WinXP Home vs WinXP Pro and the SP status i.e SP1 or SP2 ]
See
http://support.microsoft.com/default.aspx?scid=319136
Jan 12, 2010 | Microsoft Windows XP Home Edition
Reinstalled Windows xp professional to my acer aspire 3610
1.change another Installation CD of Windows XP service pack 2 or install Windows Vista.
2. if any track of your CD is corrupted, then this type of error comes.
3. sometime if your hard is not formated correctly, then also some fatal error comes.
4. when formating always do full format, donot do quick format.
Jun 23, 2009 | Acer Aspire 3610 Notebook
Dear guys, a few days ago i boght a used-notebook. GoBook ix250. and now i've problem with it. there had been windows xp sp 2 in it, but error frequently. I want to intall a new windows installation to...
I would try to error check the hard drive and also run a memory check to make sure it's not introduction errors. You'll need a floppy drive for the memory check and if the hard drive is over 30 gb, you'll have to hook it up to a desktop with an adapter as a slave to a winxp installation or, divide it into smaller 30 gb or less partitions, format with fat32 using a win98 startup disk and then scandisk each partition, checking for errors.
Feb 03, 2009 | Itronix GoBook IX250 Notebook
BAD_POOL_CALLER
Try a Repair Install with your WinXP Bootable CD. If Repair option fails you will have to do a Clean Reinstall of WinXP as a last resort.
Some details:
1. Boot with your WinXP CD
2.At the "Welcome To Setup" screen, Choose the option:
To setup Windows XP now, press ENTER. DO NOT choose !!!! To repair a Windows XP installation using Recovery Console, press R. IGNORE
To quit Setup without installing Windows XP, press F3
3. Accept the License Agreement and Windows will search for existing Windows installations. 4.Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, under the Circumstances you are in the next option will be Clean install
5. I this does not work it might be your memory --download and burn to cd memtest (http://www.memtest86.com/) and test your memory for errors.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
My Dell Latitude LS wont Boot up!!!
Repair your operating system. Insert your WinXP installer. It will search for your previous windows. There will be options like installing a fresh copy or repair your previous windows. Choose repair.
Dec 22, 2008 | Dell Latitude LS-H500ST Notebook
Windows XP installation error
i have had the same problem when the hard drive was about to die or the ram is faulty
take ram out and clean gold edges with rubbing alcohol or a pencil eraser,
insert ram, if you have more than one chip try one at a time as one may be failing, ie (a bad spot on the chip and only stops the install when it gets to that location on the ram chip)
when you are running the install ,windows will ask you if you want to use the partitions on the drive
,say no and delete select partition ,this will format the hard drive and set a new one up,if the drive has problems it should show up then.
good luck ,and let me know how you go
Terry
Mar 31, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
