Question about NEC MultiSync VT580 Multimedia Projector
NEC VT580 Power light is on solid, projector does not turn on
Nec VT580 Power light is on solid projector does not turn on at all with starting up lamp or fan. Status light blinks when you push the power on button. Does this mean the unit needs to be brought into a service center?
Gigatech
  • 259 Answers
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
dhiman
  • 115 Answers
SOURCE: NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Posted on Feb 07, 2008
SOURCE: Flashing red status light on NEC VT45 projector
Press and hold down the help button on the remote pointing it towards the projector for at least 10 secs.
Posted on Mar 03, 2008
Gigatech
  • 259 Answers
SOURCE: Blinking status light
6 cycle (0.5 sec On,
0.5 sec Off) is a lamp error!
0.5 sec Off)
Lamp fails to light. Wait a full
minute and then turn on again.
Even though the lamp is not old there may be a defect in the lamp. I know the lamps are expensive but this may be the problem. If you have a lamp that was removed due to age but still worked you could use the lamp to test it.here is a link to the user manual:
http://www.iusb.edu/~libg/ims/VT570_MAN.pdf
Hope this helps. :}
Posted on Apr 02, 2008
SOURCE: NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
Posted on Aug 26, 2009
How do i reset prOjector lamp vt595
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 10, 2015 | NEC VT85LP Projector Lamp for VT480, VT580
Nec green pictures
it seems that the lcd panels are failed
Have a nice day!
Jerry
Lampdeng Limited
Apr 03, 2014 | NEC (VT85LP) Projector Lamp for VT480,...
Nec vt480 green images
It seems that the lcd panels are failed
Have a nice day!
Jerry
Lampdeng Limited
I have a NEC projector with a solid red light and it wont turn on.
maybe
the lamp ballast is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, motherboard,
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 20, 2014 | NEC VT58 LCD Projector
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
How to you flip the image on the VT85LP projector. It is in the ceiling and I want to flip the image.
You n eed to check the settings menu and change the orientation setting for the projector so that it is set to ceiling/front.
Good luck
May 16, 2011 | NEC VT85LP Projector Lamp for VT480, VT580
The ceiling mounted projectors image is upside down, how do i turn it the other way?
Go to the menu, in the "Setup" section, then go to "orientation"..and select "ceiling"...image will invert for you.
Good Luck
Aug 12, 2010 | NEC MultiSync VT580 Multimedia Projector
327 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
