Question about Nikon COOLPIX S51 Digital Camera
Clock symbol what is the flashing clock symbol when i turn on the camera? It shows a white circle with hands at 9:00.
Reset the date and time by using the Set Up Menu and the problem will resolve itself
Posted on Feb 17, 2009
Low battery showing replacing batteries does not solve problem
The flashing low battery symbol is the way Canon film cameras showed that the camera has had an error and has stopped functioning. It can have multiple causes - but for a quick check remove the lens, turn off the camera and then turn it back on - see if the symbol stops flashing. A problem with the lens can also cause this problem (usually a failure of the aperture unit)
Dec 27, 2011 | Canon EOS 5000 35mm Film Camera
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
How do i turn on the flash?
On the menu there should be an icon that looks like a yellow lightning bolt with a red circle around it and a red line thru it (this means that the flash is off)....in the lower right hand corner you should see a white lightning bolt. Tap the red circle 2 times and you should notice that the yellow lightning bolt now stands alone and the red circle and the red line has been removed (now your flash is on). Note: Each time you turn on the camera and you need flash, you will have to make this adjustment...I hadn't figured out a way so that it happens automatically..
THANKS.
Apr 11, 2011 | Vivitar Cameras
Red square with white circle flashing NOt self timer
It's telling you that the date and time aren't set. Go into the setup menu and set the date and time.
Apr 23, 2010 | Nikon Coolpix 4600 Digital Camera
My oven wont work afte a power cut its flashing oo:00 auto and I dont have a manual
you have 2 buttons one pops out for adjustment the other is only a push button push the left hand one repeatedly till a red clock symbol shows at top of clock then turn right hand knob to set time wait a few seconds and clock will set itself.
Nov 16, 2009 | Neff B1421 Electric Single Oven
How do i get my flash to turn back on
Hi! To turn On the flash you just need to press the flash button on the top of the camera., Flash button is like a down arrow or lightning icon., make sure that the flash symbol is set to A -icon or eye- icon or may be a down arrow symbol., if you see on your LCD a circle icon with a down arrow it means your flash is off., Gudluck!
Oct 19, 2009 | Kodak EasyShare Z650 Digital Camera
How do I turn off the flash for a coolpix 885?
There is a dedicated button (with the symbol of a lightning) for the flash. To turn off flash, press the button (maybe repeatedly) till the flash indicator on screen shows 'lightning with a circle around it'. To set it back, press the same button till the display shows Lightning and A.
Search on the Internet, you will definitely find a soft copy of the User Manual of your camera.
Jun 22, 2009 | Nikon Coolpix 885 Digital Camera
Won't Take Pictures
My nikon coolpix 4500 has the flashing red clock as well with the hands of the clock pointed to 9 oclock and a white dot on the oppostie side of the 9
Dec 28, 2007 | Cameras
Won't Take Pictures
contact nikon they know about the problem and will fix it for free
Sep 02, 2006 | Nikon Coolpix 5700 Digital Camera
What causes translucent white circles?
Vijian - I own several digital cameras, including the DSC-55. I have not experienced this problem with my camera. Try two things......adjust to "low" regarding your camera's flash setting, and secondly, put a piece os scotch tape over the flash and see if this helps. Be careful not to cover your light sensor on the front of the camera's housing.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Nikon COOLPIX S51 Digital Camera Logo
106 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
