Question about Car Audio & Video
I have a 10 year old volvo had it since new it has only done 14500 mls last week i had to jump start it as it was laid up all winter.needless to say i put the leads on the wrong terminals causing the sterio to totally fry up we have since sourced a replacement from a salvage dealer and we need to know what information we need to get for applying for a new radio code...
  • xxxxxx xxx May 16, 2010
    Quote the radio MAKE + MODEL plus ALL the LETTERS+NUMBERS on any LABELS, BARCODES or STAMPED IN THE METAL CASING
  • Car Audio & ... Master
  • 4,869 Answers
Posted on May 16, 2010
My 2004 s80 2.9 volvo has a charge prob alt new battery new this seems to last one or two weeks then click clik clik i jump it starts fine heeeeeeeeeeeeeeeeelp please
Have you had it checked for leakage whilst off? Ask for a DC current leakage test from your battery whilst the key is removed. Leakage will result in the battery draining whilst off. If the test show a leak you will need to start/looking for electrical circuits / lights remaining on.
Feb 24, 2014 | 2004 Volvo S80
My volvo stalled on me this morning and then shut off completly. I have charged the battery twice in the last two weeks with new ones. I have jump started it several times before and it did start but this...
SOUND LIKE ALTERNATOR NOT WORKING.FIRST TURN OFF RADIO TO KEEP FROM LOCKING IT OUT WHEN DISCONNECTING NEGATIVE BATTERY.REMOVE ALTERNATOR HAVE IT TESTED.BEFORE REMOVING ALTERNATOR MAKE SURE DRIVE BELT HAS NOT WORKED LOOSE OR BROKEN.
Nov 04, 2011 | 2002 Volvo S80
Had a dead battery Thursday a.m. got a boost. Took it to have the battery tested. Guy told me it was 5 years old, testing not bad but recommended a new battery with winter coming. Today. dead battery...
There is a switch above the break peddle that is adjustable for the break lights. This is running your battery down that is why the gauges are jumping. Change the battery.. If it is 5 years old draining it dead will kill the cells. Hope this helps.
Oct 20, 2010 | Pontiac Montana SV6 Cars & Trucks
94 Volvo 850 GLE Sedan with 140k miles. It turns over but will not start. Put 2 gallons of new gas in a very low fuel tank, along with Heat in the tank. The temp has been below zero for the past week, the...
when was the last tune up...and check the battery make sure its not frozen just because it jumps doesnt mean it has enough power to crank even if your jump starting and check the belts
Dec 18, 2008 | 1994 Volvo 850
Volvo S70 won't start - battery, generator, or other
usually multiple clicking (like a machine gun) does indicate lw battery voltage. did you get 11.9 volts with it running or car off? with running you should be over 13.6 min up to 14.0 volts. these cars have a fair amount of electronics with some residual voltage draws which may shorten battery life. 4 yrs is not too bad. i would consider replacing battery
Dec 13, 2008 | 2000 Volvo S70
Gas furnace cycles on then shuts down
COULD BE A ROLL OUT SWITCH ,OR GAS PRESURE TO HIGH TRIPPING ROLLOUT SWITCH COULD BE A FLAME SENSOR ,TELL ME MORE IF POSSIBLE
Nov 21, 2008 | Water Heaters
Squealing sound
We have had the same problem and upon removing the main circulation pump, I found that the housing had come apart and had to order a new pump and install it. But the problem did stop there. The pump that discharges the dirty water has two stainless steel ball bearings in it and was worn out. So now I have to replace this pump also..... this needless to say, will be my last fridgidaire dishwasher. The unit is not ever six years old and might be used once a week.
Sep 02, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
