Question about Jenn-Air JSD2789GES Side by Side Refrigerator
Water freezing on bottom of freezer
Water building up in bottom of freezer and leaks under door
  • 375 Answers
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
My fridge is leaking, water drips out once day from the left side where freezer side is.
Not sure what model you have or the age, but it could be the door gasket. It could also be the door closure at the bottom of the hinge side being worn down and not closing the door all the way. These normally last about 15 years.
Nov 02, 2017 | Refrigerators
I have a Jenn-Air side by side refrigerator. It has built up ice in the very bottom about three inches thick. What could be the problem?
ice is water freezing so check where the water is getting in ( leaking water bottles being frozen, bad door seals, too frequent door opening etc
Jul 10, 2016 | Jenn-Air Refrigerators
Water is collecting and freezing on the bottom freezer.. Overflow water is leaking on to floor,
bad door seal resulting in condensation and water leakage. secondly a bad defrost terminator will cause a build up of ice in freezer
Mar 12, 2015 | Whirlpool Refrigerators
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
The defrost drain pan is plugged and not allowing the water to drain into the pan under the refrig. Remove the cover on the back wall of the freezer and clear the drain by flushing with hot water.
Mar 25, 2010 | Jenn-Air JSD2789GES Side by Side...
Water build up back of freezer inside drips to bottom and leaks from under door.Looks like their is some sort of tray with hole in back then it overflows drips to bottom of freezer some of water freezes...
Our GE Profile leaked from the freezer door and this is what I was told by a service man to try before he came and it worked. There should be a "well" on the bottom of your freezer floor where the water runs when it defrosts. Yours is probably now covered with a sheet of ice. You can melt the ice with a hairdryer using dry towels to soak up the water as you work or really hot wet rags and ring them out in the sink. After all the ice is removed pour a small amount of warm water into the "well" and stick your finger in there and "plunge" it - like you would a clogged toilet - with your finger. This will purge the ice that blocked the drain. Check on this every couple of months to make sure you don't end up with the same problem in a year or so.
Jun 12, 2009 | GE GSS25JFM Side by Side Refrigerator
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Kssp42qhwoo(7 yrs old)
Check and make sure you defrost drain in the freezer isn't frozen. The water may be coming from the bottom of the freezer inside. When the heater comes on to defrost the evaporator, the water drips in to a small hole in the back bottom of the freezer inside. If the drain freezes, the water runs out into the freezer on the bottom and eventually onto the floor in front of the freezer door. It will eventually create a gap and let moisture into the freezer and may show up in the refrigerator section as condensation. Remove the ice build up including the alluminum drain pan area where the drain is located. Pour hot water into the drain to defrost it. You may have to remove the back of the freezer wall on the bottom to get better access. If the water goes down the drain, its clear. If you need a part for your refrigerator, please email me on ebay under user name themackshack. Good luck! , Mack
Jan 06, 2008 | KitchenAid KSSP42QKS Side by Side...
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
113 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
