Question about 3Dconnexion SPACE EXPLORER 3DX-700026 Keyboard, Mouse
Using 3D connexion in Solidworks the model flies off screen
Hi I'm using a 3D connexion Space explorer to control the solid model in Solidworks. Sometimes when i touch the cap of the Space explorer the model flies off the screen. i haven't adjusted the sensitivity or anything like that it just seems that one of the axes is a bit faulty. Its a newish controller i had it from new. It just seems bit jumpy. Just wondering has anyone had any issues like this?
Por favor, necessito de baixar o driver para o equipamento HP EF390AA Spacepilot Intelligent 3D Controller
Portuguese:
O HP SpacePilot 3D é uma versão OEM do SpacePilot da 3D Connexion - voce pode baixar os drivers da página http://www.3dconnexion.com/service/drivers.html selecionando a opção PRODUCTS > OLD PRODUCTS > SPACEPILOT . Marque também a opção "Also show archived* software" para ver drivers e plug-ins de softwares especificos, como AutoCAD, Maya, Blender, MicroStation, etc. Boa sorte!
English:
HP SpacePilot 3D is an OEM version of 3D Connexion's SpacePilot controller - you can download its drivers from the following link: http://www.3dconnexion.com/service/drivers.html . Select PRODUCTS > OLD PRODUCTS > SPACEPILOT . You should also mark the "Also show archived* software" option to look for specific plug-ins and drivers for some programs like AutoCAD, Maya, Blender, MicroStation, etc. Good luck!
Oct 25, 2010 | HP SpacePilot 3D (EF390AA)
Silcone Graphis With SDRC Ideas Master series
There may still be some people who can do it, best shot is to go with a new one. Ask around local pc repair shops / etc.
Jun 27, 2008 | SGI Silicon Graphics Silicon Graphics 230...
Using certain cad programs, can not see my work?
You don't mention the program so I can't tell you specifics but generally 2d such as autocad want a Heidi driver or a newer direct-x. 3D cad such as solidworks can be very picky what video cards they will work with. Generally direct x or open-gl must be supported along with minimum ram and certain chipsets being required.
Jul 09, 2009 | Computers & Internet
Space bar doesn't always work and a line sometimes appears when Caps are used
The batteries may be low or if that does not work just buy a new keyboard.
May 11, 2009 | Computers & Internet
No connexion true activeSync
I as follow:
Start, settings, connections, Usb to pc, clear the first Square box if it ticked. It will sort your problem.
Apr 30, 2009 | HTC Touch Diamond Smartphone
Cannot Delete Files on HTC Touch P3450 SmartPhone
Try installing some other file explorer such as Resco File Explorer and then try to delete the files. In case you get the error message again, tap and hold the file in Resco Explorer and click on Properties and remote the checkboxes for Hidden, System, Archive. Tap Ok and then try to delete.
Mar 31, 2009 | HTC Touch P3450 Smartphone
SpaceNavigator rotates without use
I also have this problem. I have tried reinstalling the 3dConnexion drivers (sometimes works) and unplugging/replugging the SpacePilot Pro (sometimes works), and rebooting the computer (hasn\'t worked).
Alternatively, the thing doesn\'t work at all--the LCD display is fine, but it won\'t even run the "Trainer" application that came with the latest drivers. That\'s where I happen to be right now.
BTW, then things spin in SolidWorks, they also spin in the Trainer application, making me think it\'s more a problem with the SpacePilot Pro, or the installed 3dConnexion drivers for it.
Mar 28, 2009 | 3Dconnexion SpacePilot (133031000) Mouse
Solidworks 2007 patch
according to me you can find a patch either on the desktop after installing the program or in the strat menu if not then just browse to progarm files in the drive where you have installed your O.S.
Jun 22, 2008 | Microsoft Windows Vista Ultimate Edition
How do you install solidworks 2006-2007 student edition on a vista capable laptop
Put the cd-rom inside your harddrive,and itll automatically do it for you, all you do is put next...
Apr 26, 2008 | Computers & Internet
Scroll wheel function
You can try using the windows driver for a generic 3 button or wheel mouse. That may require that you go to control panel system hardware and then find your mouse then select update driver and pick one of the generic or microsoft drivers that have the same functions. The problem may show up when you reboot and windows tries to reload the original driver.
Nov 06, 2007 | Logitech Cordless Desktop MX3200 Laser...
3Dconnexion SPACE EXPLORER 3DX-700026 Keyboard, Mouse  Logo
73 people viewed this question
Top 3Dconnexion Computers & Internet Experts
David Payne
David Payne
Are you a 3Dconnexion Computer and Internet Expert? Answer questions, earn points and help others
