Question about Zebra Z4Mplus Label Printer
How do I configure a Zebrazm4 Plus printer for a
How do I configure a Zebra ZM4 Plus printer for a continous label
  • 96 Answers
Press the setup button. press next until you get to media type, change from non-continious to continious using the upper config buttons. press setup and next to save permanent. Also you can download Z4Mplus user manual from zebra.com.
Posted on Nov 21, 2010
2 Suggested Answers
  • 97 Answers
SOURCE: How do I configure a Zebrazm4 Plus printer for a
Usually the easiest way to do this is to make sure the printer driver you're using is set for continous labels. This setting will vary depending on the driver / software being used to print labels. You can also go into the SETUP mode on the printer and make sure MEDIA TYPE is set to continous. Be aware that most printer drivers will override the setting in the printer. You may set to continous in the printer but if the software is set for die cut labels, then the printer will act for printing die cut labels when a format is sent to the printer.
Posted on Apr 06, 2010
I changed the Label Roll in my Zebra QL 220 Plus. After I turn on the printer it prints labels continuously and on the screen it shows "Extended Two Key". How do I get rid of this problem?
Extended two key means one of the buttons by the LCD are sticking and not releasing, you use the two key sequence to print a device configuration but if you hold in the buttons for too long r they are sticking that's when you get the extended two key error.
Nov 18, 2014 | Zebra QL 220 Plus Label Printer
Zebra printer drops network
i hadthe same issue with all my zm400's, but not my zm4 plus's. zebra gives you the run around when contact their technical support.
I tried every setting there was, ended up get rid of the zm400's, they are a piece of C#@P
Feb 03, 2012 | Zebra ZM400 Thermal Label Printer -...
Mar 25, 2010 | Zebra Z4Mplus Label Printer
Prints larger that print preview shows...
Firstly make sure your using the correct drive ZM400 rather than Z4M. if you are using the applications driver make sure of headers and footers sizes and the print area is set correctly. If your using odd sized lables download some new drivers from the Nice Label website, they are far more adjustable that the standard Zebra drivers.
Aug 29, 2009 | Zebra Z4M Printer
Zebra Z4M Plus
Is the length of the label correct on the configuration print out?
Else try t check if there isn't a feed or print adjust in the parameters
Jun 25, 2009 | Zebra Z4M+ Printer
Zebra zm4 won't print labels all the way.
Please check your driver settings, you will probably find that you have the printer set to use the 2x2 labels instead of the 2x4
Jun 23, 2009 | Zebra Z4M Printer
Want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
May 04, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Small label is being cropped at the top
Have you tried the menu settings for start top of label? If other printers work, you are talking about a configuration setting. I would get a configuration off another printer that works and look at yours real close.
May 01, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Un able to configure zebra ql 320 plus barcoda printer
are you using software called label vista from Zebra? this is the only way to configure this printers on a easy manner. you will need a usb or serial cable and also remember that if the printer does not have paper on it, it will not configure. let me know if you need more help with this as i know the product very well.
Mar 10, 2009 | Zebra QL 320 Thermal Printer
Printing mixup
Your problem is a computer configuration issue, not a printer problem.
Without knowing any details of your system configuration, it is impossible to offer and further advice.
Steve W
LazerTek, LLC
Jul 02, 2008 | Zebra 140XiIII Plus Thermal Label Printer
Zebra Z4Mplus Label Printer Logo
279 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
