Tv screen Panasonic tv screen shaking and the picture sometimes to show black at the bottom of the screen moving upward
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Very common problem you have a verticle problem either you have filters that are leaking or your verticle ic is going bad in the shop depending what size this unit is and weither it is a tube set ot a lcd or plama or led
Posted on May 18, 2010
Picture tube failing?
NO thats not the picture ,that is more from the vertical circuit some capacitor defect or the ic it self
hope thet will help you
regards Alan
Jun 07, 2010 | iLO 2600 Television
Pt61g42v.this is a panasonic 61 FOCUS OUT
my tv flat lined the screen went black with a twisted line across the screen what is the problem?
May 13, 2010 | Televison & Video
I believe the blue lamp in my 57H81 is going bad.
You need to replace convergence out chips in your Toshiba 57H81 tv by qualified tech because 3-D look picture in rear projection tv shows some thing wrong with convergence output chips.
Your tv model number shows it is rear projection tv that use 3 tubes to make color picture on front screen where as dlp tv use one lamp as back light source to present picture at front screen that is generated in light engine.
Mar 25, 2010 | Toshiba 57H81 57" Rear Projection...
Tv screen
Sound like you have a verticle problem caps and verticle ic need to be changed do you think youll want to try you need soider a iron and ic and caps
Mar 25, 2010 | Televison & Video
my panasonic model PT61G42V screen went flat lined and went blank still has sound, wwhat should i do?
Mar 22, 2010 | Panasonic Televison & Video
Panasonic PT53wx42f screen problem
if the tv was moved drastically and shaking it or it was dropped by accident there are two chances to have a problem:
  1. the tv suffer a severe miss of adjustment
  2. some problem in the printed circuit board (a little crack in the PCB or solder joins broken
in any sense a visual inspection could determine the solution in the bench.
Apr 14, 2009 | Panasonic PT-47WX49 47" Rear Projection...
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Black triangles
Power supply problems inside the tv...Usually related to Capacitors drying up over time. Send to qualified tech for repair, or replace.
Nov 15, 2007 | GE 25GT240 25" TV
TV picture has moved up
your pic. has shiffted vertically. very easy to fix. open the tv set, located the crt tube(end of the screen) there are four wires going down to the board that is compined in one socet. around that socet, you will find small knobs, look for vertical phase and you could adjust that pic. the adjusting should be done while the tv is on and has pic so be careful, you are dealing with a live electricity. good luck
Feb 28, 2007 | Beko 324250WN 28" TV
Televison & Video Logo
257 people viewed this question
Top Televison & Video Experts
Electro Med Services...
