The cold water supply does not come into the washing machine for a Kenmore 80 series. I can only use the hot water side and it is shrinking all of my clothes. The Model No. Is 110.28812790 and the Serial No. Is CG2915668. What part do I need? Please help!!!!
  • 343 Answers
Most common reason is that the water inlet valve has failed and needs to be replaced..Not a big job..Good luck....Nomess
Posted on May 16, 2010
I have a kenmore ultra fabric care 80 series washing machine.. it will not stop filling up with water.. I have to turn off the water or it will over flow. it is very used machine... Please Help...
most likely a problem with the diaphragm of the water shutoff solenoid
diaphragms are available or get a complete unit
if it has hot and cold solenoids ( hot and cold water hoses ) and you are not using the hot just swap the hoses over and only use the hot water settings
that way the cold water comes in through the hot water solenoid
Nov 18, 2016 | Kenmore Washing Machines
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
Oct 19, 2012 | Kenmore Washing Machines
Kenmore hd 80 series,extra capacity plus. cold water will not fill tub?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jan 23, 2011 | Kenmore Washing Machines
I have a Kenmore Series 80 Super Capacity Plus Washer. It has 3 water temperature settings, Cold/Cold, Warm/Cold, and Hot/Cold. Warm is Cold and Hot is barely warm. I know I have very hot water as the...
Sorry to read about your problem, I hope this helps you out.
the inlet valves just open and close, if you have high cold water pressure, it will override the hot water. I suggest you turn down the cold water valve, until warm is kinda warm. your cold water fills will take longer, but you will have warmer water
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washing machine - cannot get
Hi and welcome to FixYa. I am Kelly. This sounds like either the hose or the water inlet valve screen is clogged. Possibly the pinhole inthe diaphram itself of the water valve. Here is what you can do.
1. Get a bucket
2. Turn off BOTH water valves at the wall.
3. Remove the HOT water connection at the water valve. Then check the inlet screen for debris. You can remove the screen from the water valve by using a knife blade on the very outside edge of the screen tugging outward. Hold the screen up to the light check it for debris. If it is dirty wash it under a light flow of water in the sink. DO NOT reinstall just screen just yet.
4. Use a measuring cup or something similar to catch water at the water valve HOT connection. Select a WARM wash cycle and start the wash cycle. Let the water flow into what ever it is you use to catch the water exiting the HOT water connection.
Tap on the cold water hose connection to try and free the debris inside the water valve as the water is flowing. Do this a few times until you have let water back flow through the water valve for about 20 seconds.
Machine timer off.
5. Reinstall the inlet screen in the water valve and reconnect the hose. Place the HOT water hose in the bucket and start the WARM fill cycle again. This will flush the hose.
Machine timer off.
6. Reconnect the hose at the wall connection and turn on the water at the wall.
7. Select HOT wash and test water flow. It should by now be (fingers crossed) flowing.
You can repeat the above for the cold water side if you need to.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore HD Series 80 - hot water trickles in.
Pull the two screws at the bottom corners of the control panel. Pivot the panel up. Lever the two metal keepers underneath forward and up to remove them. Tilt the housing forward and pull it toward you to remove it. Make sure you unhook the lid switch wiring plug before you remove the housing.
Water inlet valve should all be one piece for hot and cold.
Nov 15, 2009 | Kenmore 26882 Top Load Washer
No cold water going into tub, valve is open
make sure the hoses are not kinked and check the screens inside the valve inlet and make sure they are not clogged
May 25, 2009 | Kenmore Washing Machines
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer: no cold water
easy way for me to determine problem is reverse the hoses on the machine still no cold??? should be no hot now!! in which case you have a bad water valve no cleaning need to replace
Mar 01, 2008 | Washing Machines
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
