Question about Dell A920 InkJet Printer
All in One Dell Center will not work
My printer was deleted from my computer. Since I do not have the software cds anymore I retrieved the drivers and downloaded them online. Now the all in one center will not work with those drivers. Wehn it scans, I want to save it as a pdf and I cannot do anything with it Thanks
    Sergeant:
  • 399 Answers
To get all the installation instructions click the link directly http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&l=en&s=gen&dn=FA1093020 thanks.
Posted on Jul 15, 2009
Cannot retrieve scan applications list from computer
Check to make sure you have all the appropriate drivers and software installed on your pc; including windows updates. You can also try re-installing the printer.
May 23, 2012 | Dell p713w AllInOne InkJet Printer
Dell 946 incompatible with Mac
CHECK THE SOFTWARE DOCUMENTATION OR CONTACT THE SOFTWARE MANUFACTURER FOR TROUBLESHOOTING INFORMATION • Ensure that the program is compatible with the operating system installed on your computer. • Ensure that your computer meets the minimum hardware requirements needed to run the software. See the software documentation for information. • Ensure that the program is installed and configured properly. • Verify that the device drivers do not conflict with the program. • If necessary, uninstall and then reinstall the program. BACK UP YOUR FILES IMMEDIATELY USE A VIRUS-SCANNING PROGRAM TO CHECK THE HARD DRIVE, FLOPPY DISKS, OR CDS SAVE AND CLOSE ANY OPEN FILES OR PROGRAMS AND SHUT DOWN YOUR COMPUTER THROUGH THE
Nov 27, 2007 | Office Equipment & Supplies
What do I need to do to utilize this printer with HP pc?
you'll need to make sure the appropriate driver and software on the supported operating system are downloaded and installed to the HP computer. You can use the CDs that came with the printer or download them from the Dell support site and make sure the printer is physically connected to the USB ports of the HP computer when trying to install the driver and software for it. Then set it as your default printer and test it
Feb 07, 2011 | Dell Office Equipment & Supplies
I have a dell 948 printer that will not scan. When I hit ''scan to computer'' it says ''downloading applications list'', then ''cannot retrieve appliations list''. I have read I should be going to my Dell...
Uninstall the existing drivers for you printer and disconenct the printer. Restart the computer. The drivers for your printer can be downloaded from this link.
Printer drivers and All in one software
***SELECT THE OPERATING SYSTEM THAT YOU ARE RUNNING BEFORE YOU DOWNLOAD THE DRIVERS***
Rate if helpful.
Jul 30, 2009 | Office Equipment & Supplies
Communication Error DELL 926 AIO Printer
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Dec 24, 2008 | Dell 926 All-In-One InkJet Printer
Epson rx560 won't align to print on cds properly anymore
you can download the latest driver from here http://driverscollection.com/?H=Stylus%20Photo%20RX560&By=Epson click the link directly and select your operating system.
Sep 30, 2008 | Epson Stylus RX560 All-In-One InkJet Photo...
Computer will not communicate with printer
Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
Cannot access scan function
Hi , did you try a manual copy thru the printer operator panel to make sure that there are no issues with the hardware , if it is copying manually then its an issue with the software , you need to uninstall the printer drivers through the Printer Disk ****make sure to disconnect the printer cable from the computer before uninstalling the drivers **** once the printer drivers are uninstalled restart the computer and get into the Safemode (**keep tabbing F8 when the system restarts for safemode**) and delete the following Folder " SPOOL " it is located under C:\WINDOWS\system32. after deleting the Spool folder restart the computer and install a fresh copy of drivers it will resolve your issue.
Do let me know once you perfrom these steps.
All the Best.
Jul 10, 2008 | Dell 922 All-In-One InkJet Printer
Install printer driver to a Dell
Unplug usb.
Delete all previous install attempts (add remove programs or brothers uninstall program from web).
Go to brothers web and download the "full software and driver package" to suit.
Run the downloaded file and follow de prompts.
Do not plug in USB until requested by software.
Cheers:)
Mar 02, 2008 | Brother MultiFunction Center MFC-440CN...
Dell A920 InkJet Printer Logo
171 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
