I am having issues with my media player 11
Windows Media Player cannot access the file. The file might be in use, you might not have access to the computer where the file is stored, or your proxy settings might not be correct.
i am running windows xp
    Novelist:
    Scholar:
  • 136 Answers
This errors generally means that the file is being used by another application. If you are reading from a usb key or a mp3 player or another application eg. winamp is using the file or explorer has it open then you may encounter this issue.
The best thing to do is is close every other application except for media center, inlcuding exploer eetc etc...also press control alt del to get the task bar up and have a look at what application is running in the back ground and turn the ones you know off as well then run it again. It may help you identify your problem.
good luck
smeags
Posted on Mar 31, 2008
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
How to connect mp3 201 to windows computer?
Hi vjedmonds...
You will connect your MP3 player to the computer using the data cord supplied with the MP3 player.
If you want to download music to your MP3 player follow the instructions below..
Please take time to rate me
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Sep 04, 2011 | Computers & Internet
Trying to media share a laptop with Windows 7 to a desktop with Windows XP. Laptop is getting the desktops files, but the desktop will not open laptop files (Media Player specifically). Upgraded desktop...
If your files are in "My Music" and the "My Documents" is not shared, then nobody can view them from another PC. Try copying the files to your shared files directory and see if you can access them then.
Jul 29, 2010 | Dell Dimension 2300 PC Desktop
Windows media player audio issues
Two things you can do; 1. install media player codecs, (that are free - google it) 2. your memory.
Jul 18, 2009 | Computers & Internet
What does no media player mean!
With every operating system you usually have a media player to play music. No media player means that either you do not have a media player that may play songs or you have a corrupted one.
Note - Media player is a Microsoft's product. You may have Winamp, Realplayer but not Windows Media Player.
Any further help, let me know.
Thanks for using "Fixya".
Jun 04, 2009 | E-Machines eMachines Desktop PC
Media player 11 playback problems
i neeed to set equalizar wich is plased in VIEW>ENAHANCEMENT>GRAFICAL EQALIZAR set it what u have it
Jan 08, 2009 | Computers & Internet
Playing media file
If you are using Window's Media Player 7 Or Greater then use the following code;
I Used Windows Media Player 11
'For Opening a file WindowsMediaPlayer1.URL = "<Drive>\<Path>\<Filename WIth Extension>"
'For Stoping WindowsMediaPlayer1.Controls.stop
'For Playing WindowsMediaPlayer1.Controls.play
Explore "WindowsMediaPlayer1.Controls." it has all the control u require
Sep 09, 2008 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Media player 11
You can always work around the problem by installing a free media player - I prefer VLC, myself. http://www.videolan.org/vlc/. If that does not work, your file may be corrupted, or it may be encoded in a format Windows Media Player doesn't recognize.
Jul 19, 2008 | Dell Dimension 8400 PC Desktop
How do I fix a drm problem in windows media player 11
DRM, which specifies whether tracks copied from CDs in Windows Media Audio (WMA) format are protected files. A license, which helps protect the copyrights of artists by preventing unauthorized distribution, is required to play protected files.
If you're trying to play your copy-protected files on a new computer, you can migrate your protected music from one computer to another by doing the following:
Windows Media Player 7.1 or later
1.
Try to play the copy-protected file again.
2.
In the message that appears, click the More Information button.
3.
Follow the instructions for migrating your licenses.
1.
Download the Personal License Update Wizard for Windows Media Player (http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0048.mspx)and follow the instructions.
2.
3.
4.
A license can be migrated ten times. After this limit is reached, you will receive an error when you try to migrate the license again (for more information, see the Windows Media Player FAQ). When this occurs, you will need to rip the file from the CD again.
note.gif Note If you still have the CD in your possession, you can rip the tracks from the CD again, but with copy protection turned off.
May 09, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
