Question about Zanussi FJD1266W Front Load Washer
Not spinning and emptying
Not finishing a programme and does not empty. Bleeps after 23 minutes and does not spin. Have removed filter and cleaned. Did a new wash and the same happened again. Any suggestions as each time I open filter water floods my floor?
  • Zanussi Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineNot spinning and emptying - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 17, 2010
Washing machine won't pump out to go into spin cycle is there a strainer that needs cleaning
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Aug 15, 2011 | Frigidaire Washing Machines
Machine is getting stuck and wont go into spin cycle.
You need to locate and clean the filter. Depending on the model (You haven't stated the model here, so I can't be sure) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 28, 2011 | LG Washing Machines
Defy automaid - just stopped spinning - all else is ok
Jul 19, 2011 | Washing Machines
Washing maching (automaid) just stopped spinning - washes but I hear the motor going through the moves - but it just does not spin. Worth getting fixed? How much will it cost? Thank you Auriel Abrahams
LG washing machine fail to spin at end of the cycle
Jul 07, 2011 | Washing Machines
The digital display jumps programmes wont empty or spin
Take the toe kick off of the machine. Reach in and up to the right. There is a "manual" which covers error codes and possible remedies but not much more. Hope your "manual" is still there.
G.
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Machine full of water and towels. Spinning at same rate then stop
Check pump filter located at rear of washer, remove rear cover, locate and remove large black hose, remove and clean filter.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
check your filter. Could be an eratic pump. Dispening draw needs to be cleaned and make sure the small hole is clear to allow the conditioner to flow through
Feb 26, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Sticking on certain programmes.
try pump you may find on longer programes pump getting to hot..and stalling
Dec 28, 2007 | Zanussi ZJ1217 Front Load Washer
Zanussi FJD1266W Front Load Washer Logo
107 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
