Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Always running, does not stay cold. every now and
Always running does not stay cold. Every now and then the temp drops and controls.
Refridgerator/freezer just keep runing temp is ok in both
Posted on Jul 19, 2010
Temperature needle stays on the hot and doesnt move even when the car is cold?
YOur guage is faulty. Your will need to replace your guage if it stays in the hot position even when your car is off and your key is out of the ignition. If it only rises to hot when you turn the key to the run position, you have a wire between your guage and your temp sending unit that has been gounded out. Usually this happens when a person opens their hood to add oil or perform some minor maintenance on the engine and inadvertantly bumps the sensor or switch or wiring. This causes about 65% of these minor issues people incur, but if it does stay all the way up with your key out of the ignition switch, then you will need to replace your temp guage.
Oct 18, 2012 | Ford Escort Cars & Trucks
Blows heat until it matches the thermostat then it just stays on and keeps blowing semi cold air. It just maintains the temp but will run all day and night. It is a heat pump with emer/aux heat. If I...
Download a PDF version of the Operating Manual HERE. ___ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Feb 01, 2011 | White Rodgers White-Rodgers 1F85RF-275...
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
98 chevy cavalier heat is blowing out cold air and temp stay at cold to .what could be wrong
Very well be the thermstat is froze. If car temp is always cold then it sends cold water to the heater core. You may want to look at the heater core (passenger side against firewall) to see if the heater door is opening. - Good luck
Oct 16, 2009 | 1998 Chevrolet Cavalier
From cold start engine warms to quater temp then cuts out leave to cool then will restart and warm up to normal running temp and stays running well after that till next cold start any ideas? the car is a...
Does the Check Engine light come ON when this happens? Whenever the "Check Engine" light comes on, there is always a DTC (Diagnostic Trouble Code) stored in the ECM (Engine Control Module). You'll need an OBDII (On-Board-Diagnostics) scanner to retrieve any codes recorded/set in ECM. Otherwise, guesswork. I have MANY ideas that could send you on a wild goose chase. I strongly suspect EMS (Engine Management System) sensor beginning to malfunction as it warms up. First strong suspicion is the crank position sensor (CKP) - however,usually always sets a DTC (i.e., P0335, P0336). The next suspicion is the Engine Coolant Temperature sensor. The ECM uses this sensor's signal to adjust fuel, timing, engine RPM, etc based on engine temp. If malfunctioning at a particuar point during engine warm up, it could be telling the ECM the temperature is LOWER or HIGHER than it ACTUALLY is, resulting in the ECM to increase fuel (flood it) or give it LESS fuel (starve it). If this malfunction lasts long enough, the ECM will usually set a DTC for that sensor circuit, either a Range/Performance code, or a "LOW Input" or "HIGH Input" code.
May 09, 2009 | 2000 Hyundai Elantra
I just had the heater blower and regulator changed on my 2001 KIA Sportage and it seems the air is very cold coming out of the vents until I drive the car. always was able to heat up just running the...
sounds to me like they have removed your thermostat as this is a real good indicatiopn of that. if you dont have one in the temp of your water stays really low as it is always moving unlike when thermostatically controlled where heat opens the valve. either way the car should be fine but will need it replacing if you live realy warm climate.
Feb 26, 2009 | 2001 Kia Sportage
Maytag mav6000 hot/cold problem
hi try to just regulate the temp by turning down the water flow from your taps if more cold is coming in than hot turn cold water down a bit to your satisfaction thanks THE APPLIANCE DOC
Sep 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Volvo V70 2.4 Estate Automatic
hello you have a thermostat problem if you leave our care running the temp probably goes to middle a soon you start driving it goes down in cold weather you gonna freeze our butt off the tyhermostat stay open water always circulate temp cannot reach normal get it change car stay cold more expensive in gaz comsuption cheers
Jan 13, 2008 | Car Audio & Video
Freezer is over-freezing
most have 2 controls in the refrigerator side. 1 is a thermostat or cold control the other is a air damper. the damper allows the flow of air from the freezer to the freshfod side. if it is closed all the way you are keeping all the cold air in the freezer and that will make it colder. most cold controls monitor the air in the fresh food section and regulate the temp. and some controls are confusing and the damper actually works in the reverse of what you think. but if the unit is always running you may have a bad cold control and it is sensing the temp in the refrigerator side is not col enough, so it will continue to run until is can be satisfyed. check the control to make sure it is shutting of if you turn it up. if not I would replace it. I dont know how old the unit is but you also may have some electronics that control the temp to.
Aug 09, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
174 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
