Question about Brady GlobalMark MultiColor (76800) Label Printer
Tape continues to retract - Brady GlobalMark MultiColor (76800) Label Printer
    Problem Solver:
  • 8 Answers
This sounds like the tape sensor is either dirty or has failed. You may be able to clean it with some help from tech. support. Brady charges a fee for access to theior tech. support, but you can get free tech. support for the GlobalMark from Graphic Products. Use the form located at: http://www.graphicproducts.com/request-support.php
Cleaning is the easy solution, there is a good chance the sensor has failed. In that case you'll need to send your printer in for repair. Graphic Products is also a good option for getting a GlobalMark repaired. They do quality work, cost less, and will get the work done faster than Brady.
Posted on May 25, 2010
Hello! the problem is that the cassete holder failed to switch to "compact cassete mode", and it is blocking.
vhc-c adapters? is that what you mean, is the battery that brings the tape out of the shell dead (aa)
retracting the tape means that the vcr does not recognise one of 4 safety states and rejects the tape to avoid damage
Apr 11, 2016 | Televison & Video
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
I found a loose part in the VCR bay I'd like to reinstall. Part #T5B
I found that part #T5B was on the bottom of the VCR tape tray on the right side of the VCR tape bay opening and was spring activated by inserting the tape to allow the tray to retract into the player mechanism. Without a tape installed, part T5B prevents the tape carriage from retracting.
However, I still couldn't get the whole mechanism timed properly, and gears were skipping teeth, the mechanism was still binding, and shutting the power for the whole player down. Therefore, I removed the rubber drive belt that operated the VCR tray insertion/ retraction process, and disabled the VCR side from operating at all. This allowed the power to remain on and allow the DVD side to work properly.
This worked only for the Phillips DVP3150V/37. I cannot say for certain if other Phillips players are the same.
Oct 12, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
Tape insertion
It's dirty inside, you need to send it off to be cleaned.
Nov 28, 2007 | Canon DV-MV830i Mini DV Digital Camcorder
Casset cover door will not open when pressed
You probably have one of two problems. Either the tape has been eaten by wrapping it around the capstan or else the head has not retracted to let the door open. If the tape will still play, then it is not the first problem. If the tape will not play, then it could be either problem. If it is the latter problem (head not retracted) then you may have a bad belt (broken or slipping). The tape wrapped around the capstan problem may be caused by a belt or tire being bad but a different belt or tire than the head not retracting problem. This may seem confusing to you but that is just the nature of the thing. In short, I'd bet you have a bad belt or tire that needs replacing. I hope this helps. Good luck.
Jan 24, 2007 | Aiwa Z-L520 Shelf System
Brady GlobalMark MultiColor (76800) Label Printer Logo
199 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
