Question about Olympus SP-550 UZ Digital Camera
Zoom error on screen and shuts off
When i turn the camera on the lens expands and the a 'zoom error appears on the screen. Then lens then retracts and the camera shuts off.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
When I try to zoom, screen goes black and "E18" appears in bottom corner
I won't say this is a solution but to prevent the lens retraction E18 message which seems to be common with Canon zoom lenses, I put the extension tube on mine. Sometimes I put a polarizer lens on it but usually I just leave it on to protect the lens when it is on. I have dropped it (on the carpeting at home) and never had a problem. If you have a Canon with a zoom lens, get a lens hood for it ASAP!! My wife's A520 has one on hers too. No problems.
There are lots of other places on the web with suggested fixes. Keep looking and keep enjoying this camera. Merry Christmas all.
Oct 31, 2008 | Canon PowerShot S2 IS Digital Camera
I have an Olympus SP 320 camera, zoom error comes up and it shuts off
I just pulled my 320 out after not using it for 4 months and the lens extended and zoom error began flashing on the screen. After reading a few other post on the net about how much it cost I decided the camera was a goner. For good measure I banged it on my mouse pad a couple times and the lens suddenly retracted and it is now working fine. Doubt it will work very often but might be worth a try. Make sure you hit it on something soft to prevent other damage.
Sep 15, 2008 | Olympus SP-320 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot A540 Digital Camera
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
Broken zoom
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 16, 2008 | Canon PowerShot A520 Digital Camera
Shuts off when I zoom or take photo
Sounds like zoom has sand in it, Or the camera may have taken a hit to the front of the len's, Lens has to be taken apart, Has to be done buy a camera repair shop/or factory. TC
Aug 25, 2007 | Fuji FinePix E500 Digital Camera
Photosmart m627 camera
It sound like a problem with the zooming mechanism, does your camera was dropped down ? In case it dosen't, since your camera is still under warranty, best thing will be sending it to the appropriate factory service center for repair the problem. Good luck!
Aug 13, 2007 | HP PhotoSmart M627 Digital Camera
Olympus SP-550 UZ Digital Camera Logo
42 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
