posted by btrady on Mar 31, 2008
at base of fan are 3 blk wires connected plus the blk wire running down to the light, 2 wht at base plus 1 going to light ? pull switch for light has 2 blk wires . the light is on but if i pull the chain to turn it off it will blow the fuse.what did i do wrong and where do the 2 blk wires fron the pull switch connect to?
This Problem Also Relates To:
Black & Decker Black & Decker Black&Decker Coffee Grinder Model CBM2 (220V)
Black & Decker Black & Decker CBG100 Electric Blades Grinder
Bosch MKM 600 Blade Coffee Grinder
Black & Decker CBM205 Grinder
Cuisinart Grind Central DCG-12BC Blades Grinder
Cuisinart Grind Central DCG-20N Electric Blades Grinder
Cuisinart Grind Central DCG-20NBK Blades Grinder
Can you Help with these Coffee Grinders problems?
Solis Maestro Electric Burr Grinder
solis coffee grinder
Hello , how can i buy one solis... Answer This...
Pasquini Moka H Electric Burr Grinder
pasquini moka 90 burr grinder
I need a new on/ off switch.... Answer This...
Cuisinart Thermal DGB-600 Grinder
grinder hard (impossible) to...
Fairly new DGB-600 or DGB-500. ... Answer This...
Repair Service
Find Coffee Grinder Repairman Near You:
