Question about Casio fx-300ES Calculator
How do you enter or solve for x? ex: 4/5 x = 6
  • Casio Master
  • 8,073 Answers
Take the time to read the whole post. It explains the use of variables on the calculator. The use of the solve( function is at the end of the post.
The variables you have at your disposal in this calculator are
A, B,C,D,X,Y,M. All of them are accessed by pressing the [ALPHA] key before the key near which is written the name of the variable. You will notice that the markings of the symbols accessed with the [ALPHA] key are of the same color as that of the [ALPHA] key.
You will notice also that there are two = signs.
The one at the bottom right executes the command line. By pressing it you find the result of the expression just entered.
The other = sign is marked on the body of the calculator with the same color as the [ALPHA] key. It is located at the top left of the keyboard (excluding the row with SHIFT, MODE, the navigation buttons)
Example to enter X^2-2X-35=0 (not your expression)
Direct access physical keys are in [ ],
[ALPHA] (X) [X to power 2] [ - ] [2] [ * ][ALPHA][(X) [ - ] [3][5] [ALPHA] (=) [0]
Usually when you enter such an expression it is with the intention of solving it for X. By default X is taken to be the UNKNOWN. You will be prompted to enter the value assigned to any other letter symbol (Y, A,B,C,D).
So, if you want to use the Solve function, you press [SHIFT] [CALC] and the calculator will ask you a question: "Solve for X?" , and you press the = sign at the bottom right.
Then you will be prompted for any other non-X letter.
Posted on Aug 24, 2010
How to enter exponents ex. 10 to the 4th power???
Press 1 E 4
The E means "times 10 to the" so 1E4 is 1*10 to the 4th 10 to the 4th.
Oct 16, 2013 | HP 33s Calculator
Setting time and date canon electronic calculater lc-64t
With switch in set position hit date. Hit the date button (X) and then enter the year in (4) digits (ie:2013) then hit the (X) button. This will enter the year. Enter the month and day in (4) digits (ex: 0615) and hit the (X) button again. This should set the date for you..ie:6/15/2013!!!!! For time in set position enter time (ex: 346 and hit PM button if afternoon and then press time. This should give you 3:46pm. Hope this helps.
Dec 08, 2012 | Sharp EL-1750PIII Calculator
HOW TO SOLVE STANDARD DEVIATION PROBLEMS
Here it is.
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
for 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Feb 02, 2011 | Casio fx-300ES Calculator
BSNL 3G Seetings
Compose message MobileMake MobileModelno and Send SMS to 58355 for Automatic GPRS/WAP/MMS settings.
1. Ex: if you have a mobile Nokia 6600
NOKIA 6600
2. Ex: if you have a mobile Sony Ericsson w810i
SonyEricsson w810i
3. Ex: if you have a mobile Samsung sgh-e700
Samsung sgh-e700
Then you receive 3 or 4 settings save those settings in your mobile and set those settings as default settings. In case if your mobile is prompted for PIN, enter 1111.
Jan 09, 2011 | Samsung S5620 Cell Phone
Casiofx300w when i enter a negative number to find its square i always get a negative answer and is wrong. ex: -4x-4=16 but when i do -4square i get -16
try using parenthesis. some calculators are not interactively solving these issues they may be applying -(4x-4) ...
try (-4) x (-4)...
Cheers.
Nov 19, 2010 | Casio FX-300W Plus Calculator
well if 4/5 x = 6, then 5/5 would equal?? 7.5. 6/4 = 1.5 unit for each One. therefore 1.5 (Value of one) multiplied by 5, for 5/5 or a whole = 1.5 x 5 = 7.5.
Mar 25, 2010 | Casio fx-300ES Calculator
How do you take the 3( square root) of 64 or the 4 root of any other number? im trying to take the 2nd button but still having trouble ? can u please help?
Hi shiny_diamon
Here is a picture of the powers and root functions of your calculator.
1.To calculate the cubic root of a number you use the key combination shown on line 5
Ex: Cubic root of 27
27 [2nd] [3 root x] [EXE]; Should get 3
2. You can use the general root key on line 7 [2nd][x Root y]
Ex: Cubic root of 125
125 [2nd][ x Root y] 3 [EXE] Should get 5
(-125) [2nd][x Root y] 3 [EXE]; Should get -5
3. You can also yse the general power key on line 6: [Y to x], but the degree of the root is entered as a fraction 1/3
Ex: cubic root of -125.
(-125) [Y to x]( 1/3) [EXE]; You should get -5
4. The [Y to x[ key is the one you use to obtain all other roots fourth, fift, tenth, n-th.
Ex: Fourth root of 256
256 [Y to x] (1/4) [EXE]: You should get 4
Hope that helps.
Nov 08, 2009 | Texas Instruments TI-30XA Calculator
Can not get the cash register to program the tax properly
Try this:
Enter 3 press Subtotal enter 0125 press Subtotal enter tax (ex 8 1/4% = 8 decimal point 25) press CA/AmtTend enter 5002 CA/AmtTend press Subtotal
More help?
visit
http://www.casiohelp.com/forum
Nov 04, 2009 | Casio Parts Cash Register PC Desktop
How to change tax rate on casio 2700
Enter 3 press Subtotal enter 0225 press Subtotal enter tax (ex 8 1/4% = 8 decimal point 25) press CA/AmtTend enter 5002 CA/AmtTend press Subtotal
Mar 31, 2009 | Casio Parts Cash Register PC Desktop
How do you change the date on executone 64 phone? Our power went off & it reverted to Jan 1. I was able to change the time, no problem, but can't figure out how to change the date. Thanks!
Step 1: Press Menu key
Step 2: Press Park 3 key
Step 3: Enter password followed by # key ex. 543#
Step 4: Enter 9819
Step 5: Enter date with # in between. Ex. 01#26#2009#
Hopefully this will solve your problem.
Jan 26, 2009 | Executone 64 Corded Phone
Casio fx-300ES Calculator Logo
93 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
