Question about HP LaserJet 4700 Printer
Hp color laser jet printer is displaying error 59.co on the display pannel
    Champion:
  • HP Expert
  • 202 Answers
Developing disengaging motor error
. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step
Posted on Aug 10, 2010
Hp laser jet pro 400 m401 printer 59.A0 error
SOURCE:HP color laser jet printer is displaying error
Developing disengaging motor error. Run the component test to verify that
controller PCB.
motor.
or
above steps if problem not resolved then call hp engr for 4th step.
I Hope It Works.
Sep 15, 2017 | HP Office Equipment & Supplies
How do i fix E59.00 on Hp Laserjet Pro 400 color M451dn
The 59 error indicates a motor is not functioning. check all the wiring to make sure you did not leave something disconnected after you fixed the power supply.
May 25, 2015 | HP LaserJet Pro 400 color M451dn - Printer...
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
I have a hp color laser jet 4700dtn and I am getting 59.C0 ERROR on the display screen of the printer after I turn the printer off and on.
Call HP or a printer tech.
Could be one of two problems. Both require a tech to check it out.
1)could be a bad disengaging motor
2)Or the alienation(SCIP) cams may be catching on the sheet metal inside the printer.
Either way you need a tech to check it out.
Jun 15, 2011 | HP LaserJet 4700 Printer
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
59.co printer errar hp color laser jet 3500
This error is a developer motor error not related to any color. Check the back of the printer to make sure that there is no paper jam in the exit assembly. Reseat all cartridges and restart. If it still does not start then the developer motor is probably shot.
Mar 19, 2011 | HP Color LaserJet 3500 Printer
HP color laser jet printer is displaying error 59.co on the display pannel
The "developing disengaging motor" has problems. You need a technician. Try running the component test from the control panel. Select the disengaging motor and test it. Maybe it'll start working after the test!
Mar 25, 2010 | HP LaserJet 4700 Printer
RFU load error
I have a printer HP Color Laser Jet 5550' i cont print when i on the perinter ther 59 er--co is come on printer screen and the printer can not work .waht sould i do it cont rest too plase
Feb 27, 2009 | HP LaserJet 5550 Printer
HP LaserJet 4700 Printer Logo
303 people viewed this question
Seeker5211
Seeker5211
